Supreme II vs Legato
vic78
British Columbia
Hi everyone. We are looking to buy a toilet and we're torn between the Toto Legato and Toto Supreme II.
In my research, I found that the Supreme has a MAP of 500, whereas the Legato has a MAP of 1000. Obviously this means that the Legato should have a better flush. Is this actually true?
In your experience, is the flush on the Supreme II adequate? And is it significantly worse than the Legato?
Thanks in advance!
TOTO Legato
Those seem like very different looking toilets. It is surprising that you settled on those two.
WJcandee
Wise One
New York, NY
Anything 500 or over is fine, and the Supreme II gets a greater-than-or-equal-to 500 score. The Supreme II is a lowboy toilet, so the tank is lower and the water column would be as well, so less rushiness to the water. However, any II toilet flushes and rinses well. You won't have an issue, so go ahead and get the Supreme II if you like the Supreme II better. It's basically a lowboy version of the Ultramax II. The Legato has the same Tornado flush as the Supreme II, so also should have good rinse. (Double Cyclone flush is now called Tornado flush. Same thing. "CEFIONTECT" is now called CeFIonTect, for no good reason.
By the way, I don't see a MAP score for the current version of the Legato on the MAP web site, so I'm not sure whether that 1000 is still valid.
Pick whichever one you like the looks of better. They both will work well.
