support for hose bib
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jakemembers, May 31, 2005.
  1. Jakemembers
    Jakemembers New Member
    Nov 11, 2004
    I'm installing some irrigation line and want to put in some additional hose bibs off of the main irrig. line. I'm planning to use copper for the hose bibs for strength and already read that where my PVC main irrig. line converts to copper I should ensure that the female connection is copper and not the PVC. So thanks for that.
    I was planning to add some additional support by putting a support leg between the 90 at the top of the riser out of the main and the hose bib by installing a tee and a section of pipe capped on the bottom that would also be buried. However, since the tee has a stop in it keeping me from feeding pipe straight through to the bib, water will fill this leg and just stand there. Will this cause me problems later? Are there any other suggestions for supporting the hose bib without it being next to a structure?
  2. Terry
    Aug 17, 2004
    Woodford yard hydrant for outside irrigation and hoses
    [​IMG]
    I like to use a freeze proof yard hydrant.
    I set a 4x4 treated post in concrete and use galv pipe strap to the post.
    These also have a provision to lock them off.
    The water shutoff is below ground with a drain.
    When the handle is in the shut position, it opens the drain and the water in the standpipe drains out.
    Open the valve, and the drain closes, and the water comes out the nozzle at the top.
    Woodford yard hydrants
  4. Jakemembers
    Nov 11, 2004
    That would definitely do the trick. But, we're already over budget and this looks like it would really hurt when my wife beats me with it. Also, here in Southern California, we're not concerned about freezing. Thanks for the input.
  5. Lea
    Lea New Member
    Apr 12, 2005
    Where's that hose bib
    If you do not have freeze problems water standing in the line should not be a problem for a hose bib or your irrigation lines.
    Another suggestion is to place the hose bib BELOW ground level in a irrigation valve box. Make sure the bottom is filled half way with gravel. You will not trip or have to look at an unsightly hose bib. When it is not in use pop the cover back on the valve box. Don't moan about cost, they're very cheap and you won't regret it. That's how professional irrigators do it. :cool:
    [​IMG]
Similar Threads: support hose
Plumbing Forum, Professional & DIY Advice Support studs in bathroom need new how do i thread 2 inch pvc pipes thru them Feb 1, 2017
Plumbing Forum, Professional & DIY Advice Help with Copper Pipe Support Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Bathroom Exhaust Fan Duct Support Jul 21, 2016
Plumbing Forum, Professional & DIY Advice PEX: 90 fitting or bend support? Jul 11, 2016
Plumbing Forum, Professional & DIY Advice Video: How A Farmer Shut The Fracking Supporters Up Apr 4, 2016
