Supply to Boiler and pressure reducing valve question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by philtrap, Jun 27, 2013.
  1. philtrap
    philtrap Member
    Jun 19, 2013
    Civil Engineer
    Long Island, NY
    Referencing the attached photo from the Installation Manual for the TT 100 solo, I have a question about the pressure reducing valve. It shows (unless I'm reading it wrong) the pressure relief valve looped around a ball valve. When the ball valve is closed, the water would be supplied at a reduced pressure by the reducing valve which is OK. My question is since I've never seen an installation like this:
    1) Is the reason for the ball valve so that you can fill up the system quickly without going through the reducing valve?
    2) Is the ball valve necessary?
    Thanks,
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    You don't need the bypass valve. The prv has a quick fill feature built in.
  4. hj
    valve
    1. YEs. 2. Only if you want to be able to fill and flush rapidly. 3. I usually pipe the bypass around the reducing valve, but that is just a personal preference and has nothing to do with how it works. 4. Not all fill valves have the internal bypass/quick fill feature
  5. philtrap
    philtrap Member
    Jun 19, 2013
    Civil Engineer
    Long Island, NY
    Thanks guys!!!
Similar Threads: Supply Boiler
Plumbing Forum, Professional & DIY Advice Washer supply valve VS boiler relief valve Aug 18, 2013
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Today at 1:46 PM
Plumbing Forum, Professional & DIY Advice sink supply lines roughed in wrong spot Tuesday at 1:16 PM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
