supply temp ver: return temp
Discussion in 'HVAC Heating & Cooling' started by rrekih, Apr 9, 2010.
  1. rrekih
    rrekih New Member
    Oct 4, 2009
    Canada
    I have a small staple up under floor radiant heating system.
    Right now 8 zone manifold that I am using 5 zones, will be adding 3 more zones in the near future.
    I am running supply temp of 140deg F (it actually runs at 137 / 138deg F)
    The return temp is between 126 and 128deg F, so it runs between 8 to 10deg F cooler.
    Is this a good ratio?
    Thanks for any info.
  2. hj
    If the zones were too large, the return temperature would be much lower and the "end" of the system would be starved of heat. You seem okay, but even if it were not a "good ratio", what could you do about it now?
  4. rrekih
    rrekih New Member
    Oct 4, 2009
    Canada
    It is not a finished area at the moment so I could in worst case scenario do a reconfigure.
  5. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    A tight Delta T on radiant flooring can be a good thing, offering even temps however, tight S & R temps on the boiler depending on piping can lead to reduced efficiencies.
  6. rrekih
    rrekih New Member
    Oct 4, 2009
    Canada
    I am using a total modulating tank less hot water heater.
Similar Threads: supply temp
HVAC Heating & Cooling Supply Air Temp Mar 6, 2009
HVAC Heating & Cooling Air conditioner coolant supply line to attic Aug 4, 2016
HVAC Heating & Cooling Shifting Supply & Return Main Trunks over 3' Apr 10, 2015
HVAC Heating & Cooling 15mm Gas supply in Spain Jan 15, 2014
HVAC Heating & Cooling Unbalanced oil supplyline due to de-aerator? Air causing one burner to cut out. Dec 26, 2013
