supply line sizing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by apparentgenius, May 5, 2008.
  1. apparentgenius
    apparentgenius New Member
    May 5, 2008
    Oregon
    Hi,
    I am in the process of plumbing a new house with PEX. I have a 1" main coming into the house.
    Is there a limit of how many 1/2" fixture supply lines that I can take off of a a 3/4" branch off of the main? My total fixture units on the second floor is 23 made up of 4 sinks,2 toilets, 1 tub, 2 shower heads 1 washer, 1 dishwasher.
    The distance from the 1" supply line to the furthest fixture is about 30'
    Any help is appreciated.
    glen
    http://www.terrylove.com/watersize.htm
  2. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    That depends on how your local code reads it. here in Denver you can size it as you would copper. They don't like to see that 3/8 stuff. What is you psi ?
  4. apparentgenius
    May 5, 2008
    Oregon
    Hi Plumber Jim,
    The water company says that my pressure is 65 psi at the meter. If that's the case, can I feed all of that with a 3/4" line? I'm planning on using the 1" copper ported manifolds, 3/4" inlets, 1/2" outlets.
    Thanks,
    glen
  5. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    You should not have any problems with your pressure.
Similar Threads: supply line
Plumbing Forum, Professional & DIY Advice Moving bathroom sink water supply lines Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Silly question regarding toilet water supply line -- what size? Feb 28, 2017
Plumbing Forum, Professional & DIY Advice Supply Line Pipe Type & New Stop Valve Feb 26, 2017
Plumbing Forum, Professional & DIY Advice sink supply lines roughed in wrong spot Feb 21, 2017
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
