Supplemental pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rbrtferry, Oct 9, 2007.
  1. rbrtferry
    rbrtferry New Member
    Oct 2, 2007
    Recently our well pump...down around 400 feet began to slow down and now only gives us 20 psi and runs all the time. I know it needs replacement but could I temporarily add another pump at the end to assist the water up to the top? I know of people with low pressure from city water and have had to do the same thing. I would probably connect it to the pressure switch ensuring they both kick on and off at the same time. :D
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    You have either a failed pump or a failed pipe from the pump to the tank. Someone with a clamp-on ammeter could determine which it is: Low amps means failed pump; high amps means failed pipe.
    Adding a pump will not be a satisfactory fix because either the pump or the pipe will get worse. In the meantime it would cost you a lot of money for a new pump and a lot of money for electricity to run the bad pump in the well.
Similar Threads: Supplemental pump
Pumps and Tanks Well Forum & Blog. Water is life. Well pump replacement and bad advice Yesterday at 4:05 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump issues Yesterday at 7:09 AM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Feb 15, 2017
