Reicherb
We bought a new house and found the sump pump discharging into the septic tank. I have disconnected it and it's now discharging out the side wall above ground. I'd like to turn that pipe down into the ground and run it to the ditch which is about 100' away. The current discharge is 1.5" PVC. I can only go a couple of feet down or I'll be below the ditch but my feel is that it will freeze in our Michigan winters. I believe I've seen a baffle type device that will allow the water to discharge above ground if the pipe freezes but can't find such a device. Can someone point me to one? I'm also considering using 4" pipe underground to help stop the pipe from freezing solid. Does that make sense? Anything else I should be thinking of?
Thanks,
Brad
Thanks,
Brad
