sump pump versus grinder pump or both?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rrah, Oct 5, 2007.
  1. rrah
    rrah New Member
    Oct 5, 2007
    I've searched all over the net so am hoping to find an answer here. If one has a sealed grinder pump that's hooked up to the city sewer system, does one also need a sump pump or does the grinder pump perform that function also?
    Thanks for any help in clearing up my confusion.
  2. jadnashua
    A sump pump is designed to remove ground water. A grinder pump reduces solid waste to a slurry and pumps it out. A solids pump moves solids and liquids (similar to a grinder, but needs a bigger outlet because there are still chunks).
  4. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    You would also need a sump pump if you have the ground water issue. The grinder pump should be sealed for the waist water and having ground water flow into it would also let the shit water flow back into the ground.
Similar Threads: sump pump
Plumbing Forum, Professional & DIY Advice Basement under counter sump pump Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Sump Pump Vent Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Diagnosing sump pump and drainage issue Jan 1, 2017
Plumbing Forum, Professional & DIY Advice Replacing my sump pumps before it breaks Dec 30, 2016
Plumbing Forum, Professional & DIY Advice Sump pump - replace pump or repair switch after stuck on ? Dec 18, 2016
