Sump Pump Question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by BrianP, Jan 29, 2013.
  1. BrianP
    BrianP New Member
    Jan 5, 2006
    Illinois
    Help me understand what happened. Have a pump with a "built in" check valve which is basically a rubber disk that fits inside the discharge and is held in place when the discharge pipe is attached. I inadverently left the rubber check valve out when I first installed it and upon plugging it in, it blew the bottom screen off. It seemed to be pushing air instead of sucking water. I disconnected, reinstalled with the rubber check valve and all functioned properly after that. Just curious what happened by leaving the check valve out at first. Did it allow air into the pump by not allowing a tight connection?
Similar Threads: Sump Pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
