sump pump noise
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by adams, Nov 3, 2004.
  1. adams
    adams New Member
    Nov 3, 2004
    I have a horrible water hammer noise when my sump pump shuts ff. It is an 8 ft rise and 30 ft run outside 1 1/2 pvc. I have tried repositioning the check valve from the horizontal run coming out of the pit to the vertical run, up the wall. I have tried putting the check valve closer to the pump and at the farthest point. I have tried a different check valve. I have tried two check valves. I even tried a pvc y above the check valve to an air chamber or capped length of pvc to act as a water hammer arrestor. I was going to try to put a small 3/4 inch spring loaded check valve just outside the foundation Y'ed into the 1 1/2 inch pvc to allow a vacuum break. Any other suggestions would greatly be appreciated Adam
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Is the 30 foot run outside holding water or is a gravity drain after the piping turns horizontal from the 8 foot vertical rise?. The weight of the water may be slamming the check valve shut. If this is the case, rearranging the piping could possibly help silence it a bit.
  4. adams
    adams New Member
    Nov 3, 2004
    It does hold water. I was going to install a vacuum relief check valve in that part before the long run. I drilled a small hole in the pipe to test this, it did relieve a great deal of vacuum and reduced many thumps to just one loud one. I was wondering if the flap type check valve I have in now is any louder than a spring loaded 1 1/2 pvc type? Thanks for your reply
  5. e-plumber
    Sep 1, 2004
    New York
    Banging Check Valve
    When the sump pump stops pumping, the check valve should close once, you should not be able to here many thumps. This indicates that the check flap is bouncing, again possibly because of the weight of the water. I never have installed a spring check on drainage piping so I cannot say if it would work better or not. There are check valves that have rubber on the flap to help muffle the sound when it closes.
  6. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Many Thumps?
    Are your sure it's the check valve? I'd try hooking it up without any check and see what happens.
  7. rrspsrme
    rrspsrme New Member
    Apr 15, 2009
    Did you fix the problem?
    I am currently having the same problem. It's a loud hammer and about 5 or 6 big thumps. It's not the pipe hitting anything it's the valve. I have also changed the foot valve and the same thing. I was thinking about putting in 2 foot valves to take the pressure off of the one. So I am very interested in finding out if you fixed the problem.
    Thanks in advance.
  8. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Head to your local plumbing supply store and ask for the Quiet Silent Check Valve. These are spring loaded checks that eliminate the hard thump that normal check valves experience. I have had many home owners praise me for installing this valve for them. Below is a picture , the come in clear body or solid white. Many like the clear body so they can see their pump pumping.
    [​IMG]
Similar Threads: sump pump
Plumbing Forum, Professional & DIY Advice Basement under counter sump pump Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Sump Pump Vent Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Diagnosing sump pump and drainage issue Jan 1, 2017
Plumbing Forum, Professional & DIY Advice Replacing my sump pumps before it breaks Dec 30, 2016
Plumbing Forum, Professional & DIY Advice Sump pump - replace pump or repair switch after stuck on ? Dec 18, 2016
