Sump pump discharge lines
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dx, Nov 17, 2007.
  1. dx
    dx General Contractor
    Jul 4, 2005
    General Contractor
    Michigan
    I am replacing a sump pump as part of a basement remodel. The old pump is plumbed with a 1.5" PVC line a couple of feet up to the check valve. From the valve to the outside it's 1" copper.
    Is this a code violation or a bad idea and why? I don't want to charge the client for extra work (to replace the copper piping) if it's not necessary.
    dx
  2. jimbo
    jimbo Plumber
    There may not be any code governing that pump installation, but in general the manufacturer would probably recommend not to reduce a discharge line, and 1" sounds small for a sump pump of any reasonable capacity. I suppose it 1" was adequate for the rating of the pump, then starting 1½ and reducing to 1" would not hurt.
  4. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I would not plumb it into the main drain and if it is I would repipe it out the house.
  5. dx
    Jul 4, 2005
    General Contractor
    Michigan
    Patrick, as I stated in the original post, the 1" copper line goes outside. Our local codes do not allow sumps to be discharged into the sewer lines.
    This pump is very small and rarely needed. I can't think of any reason to replace the 1" copper pipe, which is in an awkward corner. But I wanted a reality check from the pros.
    dx
  6. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Oh right missed that word "outside" my bad.
    I would repipe it to the proper 1.5"so you get your full discharge. You might have a slow season or two but that one time flood season will over whelm your pump fast.
Similar Threads: Sump pump
Plumbing Forum, Professional & DIY Advice Basement under counter sump pump Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Sump Pump Vent Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Diagnosing sump pump and drainage issue Jan 1, 2017
Plumbing Forum, Professional & DIY Advice Replacing my sump pumps before it breaks Dec 30, 2016
Plumbing Forum, Professional & DIY Advice Sump pump - replace pump or repair switch after stuck on ? Dec 18, 2016
