sump pump discharge line size - is 1.5" PVC enough?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by ct-esq, Mar 6, 2011.
  1. ct-esq
    ct-esq New Member
    Dec 29, 2008
    My submersible sump pump is rated at 55 GPM at 10ft of head. The discharge pipe rises from the pit, to the basement ceiling and then across the basement to discharge on the other side of the house.
    The entire run is piped with 1.5" Sch 40 PVC.
    I've read that the max flow on a 1.5' PVC is 42 GPM.
    Am I leaving 11 GPM behind because of this?
    I'm considering replacing the horizontal run with 2" PVC. Alledgedly, the max flow in 2" PVC is 72 GPM.
    And, with the rain and snow melt in CT, I know I need that additional 11 GPM!!!
    Any thoughts? Does it make sense to replace the horizontal with 2" PVC?
Similar Threads: sump pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
