Sump pump battery backup?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by adamw, Mar 14, 2010.
  1. adamw
    adamw New Member
    Jan 4, 2008
    Pennsylvania
    Is there such a thing as a battery backup for a regular sump pump? In other words, I want to plug my existing A/C pump into a battery backup (or UPS) and then plug the battery back up into the A/C line.
    I know there are battery backup sump pumps that can be used along side a regular pump that will kick in during a power failure, but I don't want to have install anything in the pit, or run new lines.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Battery would go dead in less than 10 minutes. They've already perfected the 12v battery backup sump pump. We use Basement Watchdog for all our installs.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    They do make a UPS unit that would support a sump pump. They use them in major data center and like facilities. Seeing that they cost thousands of dollars, it would be more effective and cost efficient to install a backup generator.
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I would recommend APC for a UPS and get one that has a rating to run the pump as long as your projected Power Outage.
    They have a model that will fit your needs, but can get expensive.
    Have a Great day.
    DonL
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would hope the OP has solved last years problem by now....
    Someone needed to drop a spam link to their blog and revived an old thread....
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Yes, I think that someone came across the old post, and just posted some input.
    APC is still the best, With a 2 Year warranty, and computer USB interface for sending Email alerts.
    Don't get much better than that...
  8. jadnashua
    A UPS big enough to run a decent sized pump long enough to make a difference during a power outage costs way more than a dedicated new battery backup pump system. the only advantage is the UPS only takes a few seconds to install: unplug the cord, plug in the cord of the ups, then plug the pump's cord into the ups. The batteries don't last forever, and if you don't monitor them, neither will work, but the dedicated battery backed up pump system's batteries are probably cheaper to replace. And, with the way most people do maintenance, the batteries will have maybe a few minutes left in them when the need arises, and you lost all your backup.
    Agreed that APC makes good stuff, but to run a 1/2-1Hp pump for awhile means much more than the typical UPS you might put on your computer. Those are designed to let it run for a bit, then gracefully turn the computer off. Needing longer-term (maybe) constant power means MUCH more money. ANd, some motors don't like the square waves or stepped waves, and a true sine-wave version is again, LOTS more expensive.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Very well put Jim. Exactly...
  10. Atlantic Mechanical
    Atlantic Mechanical Plumber
    Jun 1, 2011
    Maryland
    I wouldn't advise installing a sump pump battery backup, unless it is for a large commercial building. Otherwise, the costs associated would outweigh the benefits you get.
    That's just my opinion, but I don't do too much sump pump work.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I think if I needed a battery backup system for a sump pump, then I would use one of the Flotec 1/6 HP pumps, if it had enough flow rate.
    That would be around 125 watts and a APC computer UPS could run it for a while, and send a text message that it is on battery backup, If needed. Modified square wave should work and start current should not be a problem.
    I would not try to run a 1 HP pump, on batteries.
    Lead Acid backup Batteries have to be replace every Two years, or all effort is useless.
    Enjoy the day, take time to play.
    DonL
  12. Redwood
    Dec 15, 2007
    Service Plumber
    I would go with the Zoeller Aquanot II with the AGM (Absorbed Glass Mat) Deep Cycle Battery.
    The pump performance curve closely matches the output of the Zoeller M-53 which is probably one of the most commonly used sump pumps in this country, and users can expect 4 years of service life out of the battery with low maintenance. For longer run times you can wire in additional batteries, and in the event of a longer duration power outage recharge them off your car. The Aquanot II will provide the same pumping capacity as your main sump pump.
  13. holowinko
    holowinko New Member
    Jun 11, 2011
    Stamford, CT.
    Look into an 8D deep cycle marine battery - I sell these as an option with the battery back up systems I install.
  14. Ian Gills
    Jul 24, 2007
    USA
    I use an Optima blue top.
  15. bulldog plumbing
    bulldog plumbing New Member
    May 26, 2011
    batavia il
    sump pro
    sump pro is exactly the answer you are looking for, however i would, for my money, go with a phcc 2400 to get the peace of mind in having 2 pumps in the pit .
Similar Threads: Sump pump
Plumbing Forum, Professional & DIY Advice Outdoor sump and pump Feb 27, 2017
Plumbing Forum, Professional & DIY Advice Basement under counter sump pump Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Sump Pump Vent Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Diagnosing sump pump and drainage issue Jan 1, 2017
Plumbing Forum, Professional & DIY Advice Replacing my sump pumps before it breaks Dec 30, 2016
