Sump Pump Activation Level
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by tinye, Apr 19, 2011.
  1. tinye
    tinye New Member
    Apr 19, 2011
    OHIO
    I have a continuous flow of water into my pit.
    In an effort to reduce the on-off cycle frequency of the pump, I've set the activation point of the switch a little higher up in the pit, such that it is higher than the horizontal drain tiles coming in from the side.....so the water actually backs up into these pipes as the pit fills.
    Is this a bad practice overall, and I should really be activating the pump before it reaches the drain pipe coming in from the sidewall; even if it makes the pump cycle much more often?
    Watching and adjusting this pit is an unfortunate hobby of mine :(
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    As long as the level is maintained below the lowest point of the bottom of the slab, it should be fine. If it gets too high the water will start coming up at the wall to floor joint and/or through cracks in the floor.
  4. tinye
    tinye New Member
    Apr 19, 2011
    OHIO
    Great!
    That gives me much more height to work with, and allows a longer (and less frequent cycle).
    Thanks for the confirmation!
Similar Threads: Sump Pump
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Malfunctioning Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump loud bang Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Sump pump discharge line Aug 10, 2016
Pumps and Tanks Well Forum & Blog. Water is life. I have 2 sump pumps - one pumps to another - need advice Feb 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Sump Pump Mystery (and question) Dec 29, 2015
