Suggestions for small lawn strip irrigation
Discussion in 'Irrigation / Sprinkler Forum' started by eweneek1, Jun 23, 2009.
  1. eweneek1
    eweneek1 New Member
    Jun 23, 2009
    Have a lawn strip separated by a five foot cement walkway. The width is 5 feet, and the length on the left side of walkway is 15 feet, and the right side 20 feet. So the lawn area is 5 feet by 35 feet. Have dug a trench in the center the complete length and under walkway. So the trench is about 40 feet long. The water pressure is about 30PSI for this zone. Having trouble deciding on how best to irrigate. Will the Hunter MP strips work here? Both Toro and Rainbird strip nozzles only do a 4 foot width. Maybe I should just use 5 foot fixed sprays. If so, would triangular spacing work?
    Could extend the right side from 20 feet to maximum of 22 feet.
  2. upper
    upper DIY Senior Member
    May 30, 2009
    Fresno, CA
    Rainbird also makes a 9 foot sst that can be turned down. Upper
  4. eweneek1
    eweneek1 New Member
    Jun 23, 2009
    Suggestion for small lawn strip irrigation
    If I used the Rainbird nozzles, could use 2 15ESTs on the left, and 2 9SSTs on the right reduced down to 5 x 10 on the right if they reduce down that much.
  5. upper
    May 30, 2009
    Fresno, CA
    I would still use one in the middle for double coverage and cut the minutes....Upper
  6. tomm
    tomm New Member
    Feb 21, 2008
    Hunter has spray head strip nozzle's (not the mprotator strips) that do 5'.
  7. eweneek1
    eweneek1 New Member
    Jun 23, 2009
    Think I would need to use to many heads with the 5' fixed sprays.
Similar Threads: Suggestions small
Irrigation / Sprinkler Forum Smart controller suggestions Feb 10, 2016
Irrigation / Sprinkler Forum Suggestions to Secure a Valve Box from theft Jul 13, 2007
Irrigation / Sprinkler Forum Big booster pump, small well pump Feb 7, 2016
Irrigation / Sprinkler Forum small pump in stream - pressure switch? Tank? Jul 29, 2011
Irrigation / Sprinkler Forum New Sprinklers small problem Apr 13, 2009
