Sudden Drop in Water Pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Phillbo, Nov 15, 2010.
  1. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    A couple days ago I notice a significant drop in my water pressure. I've tested for a leak and don't appear to have one. I don't believe I have a pressure reducing valve that could be failing either.
    Looking for advice on what else to look for?
    I plan to ask a neighbor if they have the same problem next time i see them.. We are on City Water, should I call the city ? Will they charge me to come diagnose?
  2. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    I think you have to make sure you don't have a PRV in your system.
    Whether the city will charge you depends on where you live, they are all different
    Get yourself a screw on pressure gage and check the pressure on the nearest hose bit to your meter or supply line, if you are getting over 50lb it's not the cities fault.
  4. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    The valve to turn the water off to the house (other than at the meter) is on the front hose bib, there is no other valve located there.
    I'll get a pressure gauge and see what i have at the hose bib at the front of the house.
    Thanks for the advice.
  5. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    Must have been a city issue since the pressure returned to normal yesterday. I bought a gauge anyway and am getting 60 psi at the front hose bib.
  6. jadnashua
    Water pressure can change consisderably throughout a 24-hour period. In the morning, when everyone is taking showers, and again in the evening. At night, the pressure often goes up while they may be trying to replenish any water towers, plus few people are using water. So, a single check often can be misleading.
  7. hj
    IT would have to be a "horrendous" leak to create a pressure drop that you would notice. You would have a easy time seeing or hearing it.
  8. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    OK, this is strange. Again this morning (saturday morning same as last weekend ) the pressure inside the house is so low you can barely get the shower to turn on and my washing machine took forever to fill up for a load.
    I just checked the pressure at the front hose bib and it's still 60psi.
    Any advice on what to look at ? Why would it only appear to drop on the weekends?
  9. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Your GPM is low. High GPM would drop the pressure somewhat.
    Look for an obstruction upstream of both the shower and the washing machine. The pressure difference across the obstruction tells the story. The GPM on either side of the obstruction should be unchanged since water is incompressible.
    It's a long shot, but if you have a micrometer, the pipe under high pressure will have a slightly larger diameter than the downstream pipe, other things being equal. As to how much larger, I'm waiting on an e-mail answer from some copper people.
    And, in principle, since pipe under pressure is stretched it will "ring" with a higher frequency if struck with a chunk of metal, if it rings at all. I'll have to try this sometime.
    To figure out the weekend connection you'd have to be S. Holmes.
  10. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    I have a GE Smartwater water softener and I noticed that I can get an increase in pressure buy switching the bypass value. I have no way of measuring the pressure at the tub for instance but I'd guess the flow increases by about 25-30% with the softener bypassed.
    Is this typical or a sign of a clogged or failing water softener?
  11. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    And they respond:
    "The mechanical properties of C12200, the alloy used for copper plumbing tube, are 55 ksi tensile and 50 ksi yield and 8% elongation in 2 inches, for hard drawn tube.
    At an hydronic pressure of 60 psi you would not see any yielding, at such a low strain, at least one that you could measure with a micrometer. "
    Too bad.
  12. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    Try putting the pressure tester on either another hose bib (if you have another) or connect it to your washer hookups. The front hose bib is before your problem area, so the pressure is not changing. Checking the pressure at the washer will help you figure out what the pressure inside of the house is.
    Flow (GPM) depends on pressure difference and resistance. If your flow is dropping, either the pressure at the street has changed (and you have verified that it has not) or something in the house is causing a very high pressure drop. With nothing flowing, everything in the house should be at street pressure (60 psi). There can be a variation it this pressure +/- a few psi due to elevation change (2nd floor vs. basement), but it should be pretty close to the street pressure. Even if your pipes were nearly completely blocked, you should still see 60 psi everywhere when everything is off. If that checks out, turn on a sink to the tub and look at the pressure again (at the washer). If everything is normal, the pressure should only drop a bit when something else is flowing.
    If the pressure drops a bunch when you turn something on, something is causing a large resistance. Start by checking mechanical things (verify valves fully open, PRV is good (if you had one), check the softener, etc.). What type of pipes do you have and how old is the house? Galvanized pipes can close up on you over the years, but it is normally a slow progression.
    Another thing you could do is to measure GPM. Take a 5 gallon (or whatever) size bucket and see how long it takes to fill. Try to start where the water enters the house (hose bib) and then check tub, washer, sinks, etc. Some things will natually flow more water than others (tub spout vs. bath lav), but if you record what you are getting and report back, we can help to tell you if it is "normal" or not. Have someone look at the pressure tester when you do this and see when you see a big pressure drop.
  13. jadnashua
    It is possible that the water softener is partially clogged and thus you see a lower flow through it. The pressure would be the same without flow, but if the softener is partially plugged, it would act sort of like a partially closed valve. If you get the 'normal' flow with it bypassed, I'd just look there. The people on the water softener section of the forum could probably help since they deal with those more often.
Similar Threads: Sudden Drop
Plumbing Forum, Professional & DIY Advice sudden drop in water pressure in PART of the house Nov 28, 2010
Plumbing Forum, Professional & DIY Advice Kitchen Faucet's Sudden Hot And Cold Reversal Tuesday at 4:03 AM
Plumbing Forum, Professional & DIY Advice All of a Sudden - Water Hammer? Jun 1, 2014
Plumbing Forum, Professional & DIY Advice Total and complete mystery - suddenly NO water out of hot supply to tub Jan 26, 2013
Plumbing Forum, Professional & DIY Advice Sudden loss of pressure from hot/cold lines inside only??? Mar 2, 2012
