Sucking sound from well cap
Discussion in 'Pumps and Tanks Well Forum & Blog' started by tylerc, May 29, 2010.
  1. tylerc
    tylerc New Member
    May 29, 2010
    ct
    I am hearing a sucking or air escaping noise from the cap of my drilled well It happens when we are using water. I have never heard this before from any other wells i've been around. does anyone know whats going on?
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    If you are using water, something has to replace that water. Part, if not most of that volume will be air. As the water level in the well goes down, air enters the well. When the water is refilling the drill hole, air is escaping at the same rate.
    There are several things that might be different between your well and any other well which make it more notable to you.
  4. tylerc
    tylerc New Member
    May 29, 2010
    ct
    thanks
    cacher_chick
    Thank you for the quick reply. That puts my mind at ease, as I said I have been around drilled wells in several different homes and never noticed that before. Maybe I have sharper ears now that I'm Paying the bills.
    Thanks Again
    Tyler
  5. ballvalve
    Dec 28, 2009
    northfork, california
    If its sucking air, its sucking in bugs and bacteria and eventually surface water. Better get it sealed up an add a filter thats above any water intrusion. I have a well that BLOWS air out when it runs. Go figure - added a filter to a small 1/2" plug opening.
  6. Waterwelldude
    Waterwelldude Well driller,pump repair. and septic installer
    Feb 11, 2009
    Texas
    I find that kinda hard to believe. Unless you have a free flowing well.
    Your well will BLOW air when the pump is running? The only way this can happen is if you are putting water in the well faster than it can take the water.
    Now if it blows air out when the pump cuts off. That makes more sense.
    When the pump cuts off, the water it just pulled out, will rush back in and cause air to blow out the top.
    I have just never see a well blow air out the top of the seal while the pump is running.
    Travis
  7. ballvalve
    Dec 28, 2009
    Well, you are right its hard to believe and its weird. Discovered it at an open port I was using to add chlorine. Just a fine steady outflow of air only when the ssubmersible was on. Have not checked it lately. Maybe there are a lot of them and a tight seal simply means no one ever notices. I have worked on and have had a lot of wells and this is the only one. 6". 150' 60gpm. Perhaps a well would blow air if its caving in, but I lined this to bottom with 4" pvc.
    The guy with the well that sucks needs a filter. I used sintered bronze.
    Maybe I need a blowout preventer at the bottom....
Similar Threads: Sucking sound
Pumps and Tanks Well Forum & Blog Sucking sound outside? Jul 9, 2008
Pumps and Tanks Well Forum & Blog water pump not sucking Sep 5, 2015
Pumps and Tanks Well Forum & Blog sucking air in driven well Apr 16, 2010
Pumps and Tanks Well Forum & Blog Sucking Air Aug 2, 2009
Pumps and Tanks Well Forum & Blog Sand point sucking air? Apr 22, 2009
