Suck, no Suck
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by RodB, Apr 28, 2010.
  1. RodB
    RodB New Member
    Apr 28, 2010
    Minnesota
    I drove a "sand point well" with 1 1/2" pipe. The depth is around 30'. I have a 1/2 hp. pump on it and doesn't produce any water. I hooked up a (I believe it called) Pitcher Pump, where you pump the handle up and down, and it does produce water. Not a heck of a lot, but, it does produce. The pumping action takes a little effort, but, not bad. I do have a check valve on the pipe. So, what's the bad news? Is it salvagable?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    How deep is it to water? It maybe deeper than the pump can "suck".
  4. RodB
    RodB New Member
    Apr 28, 2010
    Minnesota
    I guess my question is still "why can I get water with a "picture pump" and not a shallow well pump (1/2 hp)? I now understand that a shallow well electric pump creates a "vacuum". Therefore the "hand pump", being the "picture pump", must create an actual lift of water. Or what?
  5. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Try cutting of the line between the pump and the pressure tank, then connect the pitcher pump to the priming plug of the jet pump. If you can pump water with the pitcher pump easily, then the jet pump should pump water as well. If it is hard to pump with the pitcher pump you have a lift problem or limited water in the well.
  6. hj
    The practical maximum distance ANY pump can deliver water from is about 27'. If the water is that close to the elevation of the pump, then either the pitcher pump or the electric pump can deliver water. Your electric pump is either not primed or is worn so it cannot produce the proper "suction" to raise the water.
  7. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    And 27' is with a brand new pump and zero leaks in the suction line.
Similar Threads: Suck Suck
Pumps and Tanks Well Forum & Blog. Water is life. water pump not sucking Sep 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Sand Sucker Stuck how to get out? Sep 8, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Sucking sound from well cap May 29, 2010
Pumps and Tanks Well Forum & Blog. Water is life. sucking air in driven well Apr 16, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Sucking Air Aug 2, 2009
