Subpanel in attached garage adjacent to living space
Discussion in 'Electrical Forum discussion & Blog' started by Seattle38, May 3, 2012.
  1. Seattle38
    Seattle38 New Member
    Jul 26, 2010
    Seattle, Washington
    I'm adding a subpanel in an attached garage, adjacent to living space, a common wall. I'm in unincorporated Snohomish County.
    what are the rules regarding placing a subpanel in an attached garage, in or on a common wall with adjacent living space?
  2. jadnashua
    Pretty much the same as a subpanel placed anywhere. Some, but by no means all: fed with a four-wire cable, neutral and ground bus bars separated, access space in front, above, and to the sides (don't remember the numbers).
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    yes you do see it is in red
  5. kreemoweet
    kreemoweet Member
    Sep 7, 2009
    Seattle. WA
    There may be a fire rating requirement on that wall. I'm sure your county building officials stand ready to answer your questions on that subject.
  6. jadnashua
    If the wall between the garage and the house is a firewall (likely unless it is really old), then you may want to surface mount it rather than install flush (in the wall) mount. You need to be careful about the wire penetrations in the wall to maintain a fire rating as well. How you do that can get more involved.
Similar Threads: Subpanel attached
Electrical Forum discussion & Blog Adding subpanel to new garage Jan 14, 2016
Electrical Forum discussion & Blog Cabling for subpanel Dec 28, 2015
Electrical Forum discussion & Blog Calculating subpanel/feeder size Oct 26, 2014
Electrical Forum discussion & Blog Yet Another Garage Subpanel DIscussion Jun 20, 2014
Electrical Forum discussion & Blog Subpanel location, mounting on the joist Jan 31, 2014
