Submersible Well Pump Problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cdunham, Aug 24, 2013.
  1. cdunham
    cdunham New Member
    Aug 24, 2013
    Michigan
    My submersible pump is 30ft down and it quit working about 2 months ago. I have pulled it up and replaced with a new one that is basically the same, but different manufacturer. It is used to run my irrigation, and the replacement was working and then just quit in less than a day of replacement. My pump start relay switch seems to be tripped. Whenever I try to run the system in manual mode, the pump tries to kick in, draws current from the electrical box, then all I hear is a bit of a hum. Any ideas?
    Thanks
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    A big hum indicates high amp draw.
    Is this a 3 wire pump or 2 wire unit?
  4. hj
    The hum implies that the motor is stuck and cannot rotate. Pull the pump and check it.
  5. cdunham
    cdunham New Member
    Aug 24, 2013
    Michigan
    What would cause the motor to get stuck? I just replaced it within 24 hours and it is brand new out of the box.
  6. cdunham
    cdunham New Member
    Aug 24, 2013
    Michigan
    It is a 2 wire unit. The original pump made a humming noise but it did not trip the relay switch. The new one seems to be tripping the relay switch. It is not making a big hum, but I did notice that the pump seemed to be turning off hard/louder than the old pump.
  7. craigpump
    Apr 12, 2012
    Most of the time pumps lock up due to pumping lots of sediment or running dry. Could be a faulty pump/motor too.
    What make of pump and motor have you got?
    How much water does the well make?
Similar Threads: Submersible Pump
Plumbing Forum, Professional & DIY Advice Trouble shooting submersible pump issue-20 year old pump Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Submersible pump with no tank shutting off at well switch May 28, 2016
Plumbing Forum, Professional & DIY Advice UF instead of submersible well pump cable? May 19, 2016
Plumbing Forum, Professional & DIY Advice Submersible Deep Well Pump Aug 27, 2014
Plumbing Forum, Professional & DIY Advice Submersible Pump for wet slurry / wet blasting cabinet Jan 24, 2014
