Mike M2
I have noticed lately a lack of the normal pressure in my system. I have a deep well with a 220v pump and have had it out a few times for misc. reasons. The pump is about 15 years old.
Here's what I know, the pump is continuously running. Looking at the gauge I see it is holding a steady 30psi. I tested for leaks by turning the water off just after the pressure switch and turned the pump off. It still holds 30psi steady so I know there are no leaks anywhere. I kick the pump on and it may gain a pound or two at the most but still runs due to not hitting the peak pressure. My guess at this point is the pump is not performing as it should.
I can replace it no problem, BUT I have a question! When a well guy replaced it 15 years ago he mentioned to me that I needed a special pump diameter due to the galvanized pipe having buildup inside it from age. Was he BSing me? I can't seem to find any info online about any diameter pump other than a 4 inch. Can anyone help shed some light on this? Thanks....
