Submersible Pump Size
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by lray882, Apr 4, 2011.
  1. lray882
    lray882 New Member
    May 28, 2009
    Would someone give me an idea of what size submersible pump and pressure tank I need. Also, pipe size in well and to the pressure tank.
    The well is 200' deep. The house will be 50' away. I plan to install the pressure tank in the garage. The house will have three bathrooms and one will be on the second floor.
    Thanks in advance.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    People in different parts of the country would do this differently. Maybe we can get several different ways listed here. Here is one way I would do this in my area.
    1) 10 GPM pump with check valve
    1) 1 HP 230V, three wire motor
    1) 1 HP control box
    1) 4 X 30 shroud (if applicable)
    1) 1” Well seal or pitless adapter
    260’) 12-4 jacketed wire
    260’) 1” 160# poly pipe
    4)1” Long brass barb fittings
    8)Clamps
    1)Pside Kick control package (like the pic to the left)
    (includes the CSV, 4.4 gallon tank, and accessories)
    Would also need a couple rolls of good electric tape, to tape wires to the pipe every 20’. A 4 wire slice kit. Maybe a 1 ¼” X 1” brass busing at the pump.
    Installing by hand I would use poly pipe. If I were to use a pump pulling truck, I would prefer sch 80 PVC with brass or galv couplings.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Don't forget the cable guides so that the wire doesn't chafe.
    [​IMG]
  5. lray882
    lray882 New Member
    May 28, 2009
    Thanks everyone for your comments. I forgot to tell the well water level is 50' from ground surface and the ground is level from well to proposed house. I have never used the CSV system. I do not know how available it is here in Middle Tennessee. Looks like a good idea. I was hoping to not have to have a control box. I will install the pump by hand. So looks like poly. I guess it is best if it is in one piece. I need to get the pump installed for the contractor so water will be available for construction once, the temp electric line is set. Does anyone have brands that they favor?
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    I suggested a 10 GPM, 1 HP so you could turn the pressure switch up to 50/70, and use a CSV set at 60 PSI. This is the pressure I like for 2 stories. No problem using a 2 wire motor without a control. I just like 3 wire for the capacitor start, but a lot of people use 2 wire. Call me if you have a problem finding a CSV or Pside Kick. Lancaster, AY McDonald, and Flint & Walling are three good brands. Or if you want to give your money to the big guys, try Goulds, Grundfos, Pentair. Franklin makes a good motor, but I am hearing of problems with their redesigned Jacuzzi pumps. Lot of good copies of the Grundfos out there under other names. Pentair sells under about 10 different names, but same pump. Goulds has the GS, LS, Bruiser, and several grades of their pump.
    And I never use cable guards or torque arrestors because wire won’t chafe unless the pump cycles excessively, and a CSV won’t let that happen. In my opinion cable guards and torque arrestors are just something else to help get the pump stuck in the well. I never put anything down there that is not absolutely necessary.
  7. lray882
    lray882 New Member
    May 28, 2009
    Valveman, what is the "1) 4 X 30 shroud (if applicable)" you are referring to?
    Thanks
  8. valveman
    Mar 15, 2006
    Lubbock, Texas
  9. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    valveman,
    you said something about the franklin pumps having problems? i've used alot of jclass hurricanes, hope i dont regret it.. what kinda problems?
  10. lray882
    lray882 New Member
    May 28, 2009
    Is it better to get a CSV that is adjustable? Looks like the pside kick package have one that does not. Should the poly pipe be one piece. Looks like Lowes store sales them in 100' rolls. I guess the plastic barb fittins are a no no? I am asking because I do not want to have to remove this pump for doing sometime stupid. One more question, how hard is it to drill a hole in the metal casing for a pitless adapter? As you can tell I am a DIYer.
    Thanks for your help.
  11. valveman
    Mar 15, 2006
    Lubbock, Texas
    You can order the Pside-Kick with the CSV1Z valve. That would be better for turning it up to use with a 50/70 switch. I would only use the extra long metal barb fittings. And installing a pitless in steel casing is tough, but it can be done.
Similar Threads: Submersible Pump
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
