submersible pump pumps, but no pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by JHF, Aug 6, 2007.
  1. JHF
    JHF New Member
    Aug 6, 2007
    cant get my pressure any higher than 10 psi.
    tank is not waterlogged
    pressure switch is good
    float switch for air vent is good
    no leaks
    if i vent the tank, it will fill all the way up.
    changed pump and check valve
    same thing
    any ideas??
  2. Rancher
    Rancher Guest
    What kind of pump is it?
    Perhaps a big leak?
    How fast does the pressure go down?
    Rancher
  4. JHF
    JHF New Member
    Aug 6, 2007
    new one is a dayton
    no leaks
    system holds pressure
    i know the pump is still under water
    does the pump need a certain amount of head pressure above it?
  5. Rancher
    Rancher Guest
    So it's a submersible pump, and no it doesn't need head pressure. Perhaps the gauge is bad, or the tubing going to the pressure switch & gauge?
    Rancher
  6. JHF
    JHF New Member
    Aug 6, 2007
    yes, yes the title of this thread is "submersible pump....."
    i am fully aware that my pressure gauge is working...
    i already said my pressure switch is good...
    oh yeah, and the tubing going to it...
    do you take me for a retard??
    i was kind of wondering if there was a standard depth the pump should be in a 4'' well to recover fast enough......
    or maybe someone has actually had this problem and this person can give me an idea....
  7. PEW
    PEW DIY Senior Member
    Not exactly a good response from someone looking for help!
  8. Rancher
    Rancher Guest
    Do you have an above ground check valve before the pressure tank?
    Rancher
  9. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    As long as the intake of the pump is under water just a few inches, it should pump water. It is possible that the intake screen is plugged, not enough water in the well, pump is no good even though it is new, low voltage to the motor, leak in the drop pipe, etc. Sometimes checking how many amps the motor is pulling will help us figure it out. Lots of possibilities.
  10. abikerboy
    abikerboy DIY Senior Member
    Apr 22, 2006
    VA
    I dont know you, so I dont take you for anything other than a person with a bad public attitude, but now to answer your question. Yep, Ive faced your problem, and solved it. There was a check valve in the line from the pump to the tank (actually was located at the tank), and a leak in the pipe inside of the well. Because of the check valve, the tank and the house held it's pressure, and didnt show a leak, but there was a leak in the well, which didnt let the pressure build up above about 20 on the tank. Ive learned that you dont want a check valve anywhere outside of the well except the one on the pump. And when youre on here often enough, and you check in and scan the threads, it's easy to miss out on the headlines on the threads, thats probably why someone asked if you have a submersible pump. For the depth of the pump, put it back where the old one was, and if the old one worked, the new one should work. If the water has dropped so much that water level is causing the problem, then you have more to worry about besides the pump anyway.
  11. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    While recently bench testing several submersible pumps [barrel testing] I discovered that 3 Myers pumps and 2 Dayton pumps of various sizes, castings and plastic, and HP have the 3/16 tapped holes for the wire cover on the pump head tapped ALL THE WAY THRU into the pump chamber..... which means that if a screw from said wire cover [often overlooked and under torqued] works loose, a huge leak develops in the pumping head and pressure can be slow or impossible to develop. This is not consistent in similiar pumps, some holes are not through holes, and I am rather shocked at this perversity in manufacturing.
    Anyone noticed this before??? I would say it is a very serious issue never mentioned in this forum previously.....
  12. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Yes, it's the norm not the exception. Don't leave any of the screws out.
    When you bought this pump, is it the same pump as the old one? Not just the same horsepower, but is it the same pump end as the old one?
    bob...
Similar Threads: submersible pump
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
