Submersible pump humming
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by kplank, Jul 1, 2011.
  1. kplank
    kplank New Member
    Jul 6, 2010
    Kansas
    I have a 1 hp Myers Rustler pump set at 40' in a 45' well. Static water is at 19'. 1 inch 60 lb plastic Cycle Stop Valve in the drop pipe. 1 inch poly pipe to the house. Ridged copper throughout the house.
    Every time the pump runs, there is a fairly pronounced humming sound that gets transmitted through the pipes in the house. I have changed the metal straps holding the copper to plastic hangers. This helped a little, but not much.
    Is there anything I can plumb either before or after the bladder tank that would help cut back this noise?
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is a two wire pump I do believe, and that pump has a run Capacitor built into it.
    You may want to check that it is good. there is a reason that it is humming.
    How old is it ? And did it always do this ?
    Have a good day.
    DonL
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Sometimes the length of drop pipe is perfectly tuned to the resonance frequency of the pump. Shortening or lengthing the drop pipe a foot or two will usually make it go away. An easier fix would be to use a short piece of 1" high pressure hose to splice between the well pipe and the copper.
  5. kplank
    kplank New Member
    Jul 6, 2010
    Kansas
    It has always hummed...
    At least as long as we have lived here (three years). The pump is 3 wire - control box with the capacitor in the house.
    I guess I'm not familiar with the type of "high pressure hose" I would plumb in between the pump and the copper. Right now black poly from the well, transitions to PVC at and around the tank, which transitions to copper to the house. Where do you get "high pressure hose", and where would I put it?
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I deliberately strapped a loop of the poly from the well to the underside of my floor joists so that I can hear when the pump is running. The plan was to replace the metal pipe strapping with rubber bungee cords one at a time to tune down the sound to a barely audible level but I never did.
  7. gritres
    gritres New Member
    Jun 7, 2011
    nw florida
    one likes to hear their hard work working
    i'm curious too though what type of high pressure hose you'd recommend to dampen the sound that is good for potable applications
  8. Behrens88
    Behrens88 New Member
    Dec 31, 2011
    Michigan
    Humming is good.
    I have had two pumps in my well since I have lived in my house for 10 years and both have always hummed. The newest is a 1 horse 20 GPM Areomotor that hummed out of the box. I just learned to get over it and it lets me know my pump works I guess.
  9. ballvalve
    Dec 28, 2009
    northfork, california
    Most hardware stores have 150 psi braided clear vinyl hose. I have some running at 100 psi for 10 years with no decay.
    http://www.plumbingsupply.com/cleartubing.html
    Best thing around the pump house. Quick install, quick fix and a visual of the water.
    And HUMMING is not good. Usually a sign of an issue. A run capacitor might help.
Similar Threads: Submersible pump
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
