Submersible pump going bad?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by psyclemania, Aug 6, 2009.
  1. psyclemania
    psyclemania New Member
    Aug 6, 2009
    Please help me troubleshoot my well.
    The water pressure has dropped to almost nil. I dont live in this house, so I dont know if this was sudden or gradual.
    The pump runs, so i know it is getting power. The pressure will get to about 15 psi and thats it. If I kill power to the pump, the water drains out of the house and the pressure tank, so I pretty sure the check valve is bad. With it only getting to 15 psi, the pressure switch obviously never trips, so the pump just runs and runs, I'm sure that not good for it. At 15 psi it is pretty difficult to take a shower upstairs. The well and pump was put in in 1985, so it has run pretty much flawlessly for 24 years.
    I have watched them pull the pump before when I have had breaks in the wire from "pump slap" when starting and the wire rubs against the casing. The pump is hanging at about 40' or so. I believe it is a 1/3 HP and has a control box inside. I have two 20 year old sons for muscle to help me pull this thing out, I believe all I need is a 1" threaded pipe to get the pitless fitting on the top. It just pulls up, right? Is that difficult to get on/off? What do I need for watertight electrical connections?
    I am comfortable working on just about anything, I built the addition on the house, not only doing the carpentry, but also the sheetrock, electrical, plumbing and roof. So I have DIY experience!
    Does my analysis of a bad pump sound about right? Where should I look for a new pump? I have seen them at Home Depot, and I hear Sears sells them too, but maybe this is not the place to shave a few bucks.
    Thanks all in advance for anything you might provide. I love teh interwebs!
    Philip
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    You might have a power quality problem. I'd measure current draw.
    I guess you could check a pump by hooking it to a partially closed valve and pressure gauge and feeding it with good elec. power.
    Adjust the pressure by turning the valve and measure the GPM by filling a bucket while timing it.
    If the pressure and GPM match what the pump's curve says, at both end points and one place in the middle of the curve, I don't see how it can't be a good pump/motor.
    With all the trouble of getting to the pump and the cost of these things, I'd even check new ones before installing them.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You could be running on half power (115V instead of 240V) as Thatguy suggest. Or your pump could be worn out, or a break in the pipe somewhere. Since the water drains out when the power is off, I am guessing a break in the pipe somewhere. If it is broken underground there should be a lake forming somewhere by now. So I think the break is in the well, probably at the bottom where the pipe connects to the pump.
  5. Gary Slusser
    Retired
    The check valve probably is not the problem, more likely you have a serious leak. Probably in the drop pipe in the well.
  6. psyclemania
    Aug 6, 2009
    Glad I asked!
    I had not considered that there would be a leak or the half-voltage thing. That would definitely make sense. The well-house is only about 15 feet, there is no lake, nor is there water running into the root cellar where the pipe comes inside, so inside the well is definitely a possibility.
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    In that case, assuming adequate power, using the pump curve you can guesstimate how many GPM the leak is. Look at the 15 PSI point on the curve.
  8. psyclemania
    Aug 6, 2009
    Problem resolved! Basically was a leak. Once the pump was pulled, on top of the pump is a brass fitting that connects the motor to the pipe. This actually had holes worn in it, I assume from 25 years of abrasives swirling around in there. Since the whole thing was exposed to those same abrasives and down there for 25 years, I elected to replace the entire pump. Put in a new 1/2 hp Gould, and the pressure is rockin' now!
    Thanks for everything!
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    This happens all the time. It is usually electrolysis from two dis-similar metals. If you rap those fittings with electric tape, it won't happen again.
Similar Threads: Submersible pump
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
