Submersible Pump for wet slurry / wet blasting cabinet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by NIS240SHU, Jan 24, 2014.
  1. NIS240SHU
    NIS240SHU New Member
    Jan 24, 2014
    NJ
    Hi guys,
    I'm looking to build my own wet blasting cabinet. For those that are unfamiliar, it's like sand blasting in a cabinet, but glass beads are typically used along with water to create a slurry. The slurry goes through a gun that also adds compressed air to propel the mixture toward the part being blasted.
    I'm looking for a pump that will be able to handle this type of slurry. I know that another DIY'er has used a 1HP pool pump with success, but he does say he has to replace the pump seals relatively often due to the abrasiveness of the mix. Most of the professional machines use "glandless polyurethane pumps" or "submersible polyurethane pumps" and they often also mention stainless steel.
    Can anyone point me in the right direction for a pump that would work in this application?
    Any help is very much appreciated.
    Helder
  2. pjm19076
    pjm19076 New Member
    Nov 23, 2015
    Australia
    Hi Helder,
    I too am looking to try and make a wet blasting system.
    Can you tell me if you had any success with puting one together?
    Peter
  4. David Crocker
    David Crocker New Member
    Feb 9, 2017
    Rhode Island
    Hi,
    Did you get any information on a pump for "wet blasting"
  5. CountryBumkin
    CountryBumkin Active Member
    Sep 4, 2009
    Orlando, FL
Similar Threads: Submersible Pump
Plumbing Forum, Professional & DIY Advice Trouble shooting submersible pump issue-20 year old pump Aug 22, 2016
Plumbing Forum, Professional & DIY Advice Submersible pump with no tank shutting off at well switch May 28, 2016
Plumbing Forum, Professional & DIY Advice UF instead of submersible well pump cable? May 19, 2016
Plumbing Forum, Professional & DIY Advice Submersible Deep Well Pump Aug 27, 2014
Plumbing Forum, Professional & DIY Advice New Submersible well pump won't run Sep 2, 2013
