submersible pump and pipe routing
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by gizmodiy, Jan 6, 2013.
  1. gizmodiy
    gizmodiy New Member
    Jan 28, 2012
    Toronto, ON
    I am replacing a jet pump with a submersible pump (1.2 hp, 2-wire, 10 GPM) in a lake application. In the process I am moving the hot water tank (from outside to inside - don't ask!). My question is with respect to the placement of the pressure tank, pressure switch, relief valve, pressure gauge, hot water tank as well as what's advisable in terms of bends in the piping. I'm planning on using 1" piping.
    Every diagram I have seen, including the one that comes with the pump, shows all of the above pieces placed horizontal. However, I'm short on space and I would like to have it vertical. Since this needs to drain by gravity as well for the winter, I think being vertical is that much better.
    1. Does the attached diagram look like it would work well?
    2. Is there an issue with putting the pressure switch on the piping that goes from the main vertical pip 2013-01-06 10.50.58.jpg e to the horizontal one that goes to the pressure tank?
    3. Is the 90 degree bend in the pipe (horizontal to vertical piping at the bottom the the picture) ok? Will it cause issues?
    3. What is the recommended kind of piping (PVC, copper, pex, brass, ?). I'm leaning to brass but I don't have a reason in mind. I'm reading that using two wrenches for a snug and grunt fit is all I would need for brass, no soldering. I'd use pex for all piping into the dwelling, and poly to the submersible pump.
    Thank you in advance!
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    No reason to have a ball valve between the tank and the pump. If it should get turned off the pump would just continue to run untill it burnt itself out.
    John
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I question why 1.5 HP? What is the vertical rise from the lake surface to warrant that much HP for just 10 GPM?
    Put the PRV before the ball valve, not after it.
  5. johnjh2o1
    Aug 9, 2009
    Retired
    Florida
    What would be the reason for the ball valve in that location to start with?
    John
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Only the OP can answer that. Putting the PRV before it mitigates the risk you identified.
  7. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You should not install a shut of before the pressure tank.
    You will want to have one after the tank, and then another after the water heater.
  8. gizmodiy
    gizmodiy New Member
    Jan 28, 2012
    Toronto, ON
    Sorry, typo. Its a 1/2 HP, 230V, 2 wire. The vertical height from the resting point in the lake to all the pressure take is no more than 20 feet. The distance is about 135 feet.
  9. gizmodiy
    gizmodiy New Member
    Jan 28, 2012
    Toronto, ON
    I'm fairly week in the drawing department :) At the very bottom of the picture I've tried to draw a "T" where one direction goes to the lake and the other allow water to drain out of the system when I need to void the interior pipes for the winter. The dwelling is not heated in the winter or used in the winter.
    Here's my rationale for the ball values....
    The left side of the T at the bottom is to allow water to drain out of the system without having to drain the water to the lake on the right side. This would allow me to fix any issues without having to drain the pipe to the lake. Now that I think about it I can't see a reason to have a ball valve to the right of the T ... because if the power to the pump was turned off, then I could open the left side to drain, and the right would stay filled. Does this sound correct?
    The ball valve going into the hot water tank allows me to shut off water coming in if I need to fix/replace the water tank. The valve after the water tank allows me to shut off the hot water to the dwelling in case I need to fix something inside the dwelling. I also account for some kind of T there to allow me to drain the hot water tank for the winter.
    I'm not following the suggestion on where to put the PRV? Where should it go and why?
  10. gizmodiy
    gizmodiy New Member
    Jan 28, 2012
    Toronto, ON
    Thank you for the feedback! Any opinions on
    1. The placement of the Pressure Switch, which I have on the horizontal pipe to the pressure tank? Any issues with this?
    2. The configuration being vertical instead horizontal? Any issues with this?
  11. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Or you could use one of these.
    [​IMG]
    Because the Pside-kick kit uses a CSV, you only need the 4.5 gallon pressure tank, and it can be mounted verticle or any direction you need.
Similar Threads: submersible pump
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
