Submersible loses volume and pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by lazer3691, Aug 18, 2008.
  1. lazer3691
    lazer3691 New Member
    Dec 11, 2007
    I have an 85' well with a 1/2hp submersible about 14 years old. Static water level about 25'. It has been great for doing my irrigation and domestic until this year.
    Now, it works good for my domestic water needs but when I use it for irrigation I suddenly have a problem. When it starts it works fine, but after about 5-10 minutes it dies down and looses pressure and volume. The sprinklers start surging and th pump sounds noisy. Then I have to shut it off to recover.
    I've resized my sprinkler nozzles down to a 6-8gpm consumption, and now i can go about 20min before the problem starts again.
    Any ideas on where to start?:confused:
    Thank you in advance.......
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Check the water level in the well while this is happening. I will bet the water level is being pulled down until it pumps air.
  4. lazer3691
    Dec 11, 2007
    What could cause this all of a sudden?
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    It probably happened gradually. If the static water level is still the same, the perforations or screen is clogging up. Screens usually clog gradually. You just don't see it until one day the well is only making 7 GPM, while you are trying to use 8 GPM.
  6. lazer3691
    Dec 11, 2007
    Forgive me for asking a dumb question. :confused:
    But is the screen on the pump, or the casing? Is it easily cleaned or replaced?
    Is this a job for a pro?
  7. lazer3691
    Dec 11, 2007
    bump...................
  8. Gary Slusser
    Retired
    The screen is on the end of the casing.
  9. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    It is a job for a pro.
    bob...
  10. sammyhydro11
    sammyhydro11 Previous member
    Dec 20, 2006
    Well Drilling-Test Borings-Water Treatment-Well an
    Massachusetts
    Who says the guy has a screened well? Screened wells only need to be placed at 15 to 20 feet beyond the static water level depending on the porosity of the water bearing material. I would bet the guy has an artesian well (slang around here for rock bored well). If that's the case i would consider hydro fracturing the well. Not a job for a DIY!
    sammy
    www.tylerwellandpump.com
Similar Threads: Submersible loses
Pumps and Tanks Well Forum & Blog. Water is life. Submersible Pump Feb 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Am I getting ripped off on a submersible pump? Jan 25, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. HELP PLEASE.. New submersible well pump clogging lines with shell fragments Dec 26, 2016
