submerged R10L
Discussion in 'Irrigation / Sprinkler Forum' started by bbeckwith, Mar 3, 2009.
  1. bbeckwith
    bbeckwith New Member
    Mar 3, 2009
    I'm using a Waterace R10L for lawn irrigation. It did the job just fine for one summer. I live on a fresh water canal and last fall, the water flooded the boathose about half-way up the pump.
    I didn't think to try it until the dry season (I previously had a Meyers pump which was under water at least three times and still worked). The R10L only buzzes when I flip on the power. What would I need to check to see whether it's worth fixing? It cost just over $100. at Lowe's about a year ago.
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I am not personally familiar with this motor, but I do know that most places have a minimum charge for just looking at something. It is possible to repair almost anything if money is no object, but you won't get much repair work done for $100. You might ask a local repair shop what the symptoms indicate the problem might be and if that is the problem, what the approximate cost to repair might be, but my money would be on a new unit.
Similar Threads: submerged R10L
Irrigation / Sprinkler Forum Water Ace R10L Impeller Feb 16, 2009
