submerged pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by rbig, Sep 12, 2012.
  1. rbig
    rbig New Member
    Jan 28, 2008
    Florida
    We've lived in our place approx 2 yrs. It was a constructed home, built in '97.
    Our well is approx 400' deep, and puts out around 1gpm. The pump is submerged.
    Lately, I've become aware that MAYBE my pump is putting out more "trash" than before.
    It seems it pumping lots of black sand and cliche clay. The sand is a cup or two every few weeks, and they clay cover the inside element.
    In case I'm right, does this hurt the pump at all? For all I know, it could be "normal" for this well.
    The filtered water is fine, and it's tasty.
    I was just wondering if maybe I'm going to see shorter pump life?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Yes, the sand and clay will wear away at the pump over time so maybe the wet end will wear out before the motor does. If the pump is as old as the house, its motor may already be on borrowed time depending on factors unknown to us. As the wet end of the pump wears, it will gradually produce fewer GPM and less pressure. I would budget for a replacement soon.
    With a low producing well, if the well bore is used as storage and the level pumped down considerably, it can exert significant pressure differential between the aquifer and the inside of the casing. If you use less water, the level should draw down less with less pressure differential drawing in as much sediment at least in theory. A large pressure tank represents a significant load on the well as the pump runs full-out from the point it kicks in up to the point that the tank fill to kick-out. That means that despite using less water, the pump can still draw down the level considerably on each cycle depending on the size of the bore hole.
    One approach to consider is a smaller tank combined with a Cycle Stop Valve. The CSV will meter the flow from the pump and stop the feast-or-famine cycle of the large tank.
    Another approach is to slowly pump into a large non-pressurized tank and then have a second pump draw from the tank. Of course this is a significant undertaking.
  4. bcpumpguy
    bcpumpguy New Member
    Jul 27, 2012
    Langley BC
    Depends on what type of pump end it is, I find that berkeley's with plastic floating stack impellers do absolutely fine with sand. did a flow test on a well once where i pumped out at least a wheel barrow full of sand out of a well in less then 4 hours. that pump was about 10 years old then it died about 3 years later. I consider that pretty good life on a pump.
Similar Threads: submerged pump
Pumps and Tanks Well Forum & Blog. Water is life. Do I Need to replace the wire to my submerged well pump? Mar 22, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Replacing submerged well pump soon have some questions Oct 28, 2012
Pumps and Tanks Well Forum & Blog. Water is life. water is silty since new submerged pump was installed Jan 25, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Leaving submersible sump pump submerged 99% of the time ok? May 26, 2009
Pumps and Tanks Well Forum & Blog. Water is life. how to replace a submerged well pump Mar 5, 2008
