subfloor question
Discussion in 'Remodel Forum & Blog' started by coach606, Nov 10, 2006.
  1. coach606
    coach606 New Member
    Apr 25, 2006
    I had to cut a few access holes in the new subfloor in my new attic bath to make a few changes. I will be using 12 x 12" porcelain tiles on the floor. My contractor suggests that I need to add a second layer of 1/2" plywood screwed in over the first, then a layer of cement board or other moisture barrier.
    He says that because the tile is larger sized, it will tend to come loose unless I make the floor more rigid with a second layer of plywood.
    Anyone heard of this? It will be a real challenge for me to get it done for a variety of reasons. Also, I have a double sink and I stacked two san tees to make the arms. I calculated the distance from the floor carefully and it could change things.
    Does this really need to happen to keep my tiles from coming loose? I've never heard of it before.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    Visit the Tile Experts
    Visit the tile experts at
    I think you will find that the experts recommend two layers of plywood under 12x12 tiles.
    The problem could be cracked tiles, which is more serious than an occasional loose tile.
    Also, attic floors often have minimum size joists on long spans. That is another condition that is not good for porcelain tile. They will also advise you on spans and joists.
    You should keep a good stock of matching tiles to replace cracked ones.
  4. penny mitchell
    penny mitchell New Member
    Nov 11, 2006
    We used chicken wire and a thin layer of thinset when we did a stone job in our breakfast room. Pretty stable. Try it!
  5. jadnashua
    Penny, what you did is affectionately called a NJ mudjob. The vast majority of this type of installation fails. It may take anywhere from days to years, and usually does. Use it at your own risk, there are much better ways to do it. It is not an approved method of installation. The Tile Council of America sets the gold standard for tile installations in the USA, and it has been tested and found wanting...if you want something to last, don't do it. You might be lucky, but the labor is the biggest part, and there are much more reliable, approved methods.
Similar Threads: subfloor question
Remodel Forum & Blog Bathroom subfloor question Aug 11, 2016
Remodel Forum & Blog Subfloor question about vapor barrier Dec 2, 2015
Remodel Forum & Blog SubFloor Questions - How to secure new subfloor to existing structure Sep 11, 2015
Remodel Forum & Blog plywood for subfloor questions Mar 6, 2012
Remodel Forum & Blog Subfloor question for tiling a bathroom floor with heat mat under the tiles Sep 2, 2011
