Subfloor membrane questions
Discussion in 'Remodel Forum & Blog' started by nigma444, Apr 2, 2007.
  1. nigma444
    nigma444 New Member
    Mar 15, 2007
    I've been reading up on using a subfloor membrane instead of cement backer, like Easymat, NAC ECB Anti-Fracture or NAC Strataflex Waterproofing Membrane, and Schluter Ditra.
    Has anyone had experience using these types of products? How well do they work in comparison to the cement backer? And also, can these products be used on the wall around tubs for applying glass mosaic tile? All of the instructions only talk about the floor.
    Thanks.
  2. chassis
    chassis Engineer
    Sep 12, 2005
    Engineer
    SE Pennsylvania
    Take a look at www.johnbridge.com This type of project is discussed in very great detail. Use the search feature and you will come up with alot of information.
    Ditra afaik is a floor-only product. Schluter sells "Kerdi" which is a waterproofing membrane for tub/shower walls.
    You can also use Redgard on the walls, which is a roll-on liquid membrane.
  4. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    also good is Wedi.
    The non-CBU membranes are all good; they all work; none has any kind of limitation that makes it clearly worse than any other. I don't know the NAC products.
    Some liquid membranes are designed for hygroscopic pressure and are not waranteed for showers.
    Cutting cement board makes a lot of cement dust which is a real health hazard.
    To set glass mosaic the thing that counts is the thinset, which your glass mosaic manufacturer will specify and guarantee if you are lucky.
    David
Similar Threads: Subfloor membrane
Remodel Forum & Blog Bathroom subfloor 1/2" MDO plywood adhesive? Feb 19, 2017
Remodel Forum & Blog Bathroom subfloor question Aug 11, 2016
Remodel Forum & Blog Subfloor question about vapor barrier Dec 2, 2015
Remodel Forum & Blog SubFloor Questions - How to secure new subfloor to existing structure Sep 11, 2015
Remodel Forum & Blog Basement Subfloor and Wall Insulation Dec 11, 2014
