Sub Pump wiring
Discussion in 'Electrical Forum discussion & Blog' started by JeffGr, Nov 6, 2009.
  1. JeffGr
    JeffGr DIY Junior Member
    Jul 14, 2009
    SC
    Currently I have a well 375' from the house. It is supplied via it's own meter from the elect. co. The entire electrical system is about to be condemmed. The overheads run through trees etc. I also need to replace the piping from the pump to the house.
    Getting rid of the meter will save me $180 per year in facility fees.
    The pump is a 1/2hp 110v. I plan on replacing it with a 220V 3/4 hp next summer.
    I need to install the new piping now so plan on running new electrical wiring now as well, while I have the trencher. So the pump will run off the house's electrical service eliminating all other wiring to the pump. I have a new 200 amp service at the house.
    With a 3/4hp 220v pump I can use #12 as it goes 480'. I will use a breaker box at the pump as well as a disconnect.
    Is there any economical options to use the existing pump on the new wiring? It is too long a run for 110v using #12. I would have to go #6 but the price is out of sight.
    I will be using UF cable and burying it 36" down. What is the proper way to permanently splice underground? Can I use crimp sleeves and epoxy filled heat shrink? Or do I have to try and find one run of wire? I'm rural so don't have the options of the big city.
  2. Spaceman Spiff
    Spaceman Spiff Architect
    Architect
    Salt Lake City, Utah
    Looks like you need a #6 wire for the distance and voltage drop, not to mention the drop of cable down the well pipe.
    I would run 1-1/4" PVC conduit 36" underground next to the water pipe and pull in #6 THWN conductors. Then you don't have to worry about code violations regarding depth. I'd look up the burial depth but my code book is at home...
  4. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    Do NOT run 400' of UF cable. You are asking for trouble.
    Install 1" PVC (about $200) and #6 wire minimum.
    http://www.electrician2.com/calculators/vd_calculator_initial.html
    Do NOT make splices underground. Again, that's just asking for trouble.
    Install this circuit properly and it will work for your grandkids. Cobble it together and you will hate your life.
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    You may want to consider running Aluminum type XHHW wire in PVC conduit. That might be your cheapest option.
    Jason
  6. Ford2001
    Ford2001 New Member
    Sep 11, 2009
    property care taker
    Manchester, Vermont
    voltage drop calculactor
    To: 220/221
    Me like the "Voltage Drop Calculactor" you posted.
    Where its saids: "enter 1-way circuit length in feet"
    Is it adding another 100 feet, if the one-way circuit length
    is 100 ft. ? I believe it would.
    Thanks.
  7. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    Don't forget the ground the well casing
Similar Threads: Pump wiring
Electrical Forum discussion & Blog Need advice on wiring sump pump outlet for emergency generator / 220v split to(2)120v Nov 5, 2010
Electrical Forum discussion & Blog Well Pump Wiring Nov 22, 2008
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Another question: generator power necessary for 1/2 hp pump jet pump Oct 8, 2016
