Stupid newbie P-Trap question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by notbillcosby, Sep 28, 2013.
  1. notbillcosby
    notbillcosby New Member
    Sep 28, 2013
    Iowa
    I rushed into buying a sink and vanity off of Craigslist before knowing what I was getting myself into. It's all simple enough, except for one minor issue... The new sink's drain tailpiece sits several inches closer to the wall than my old one did, making the J-bend of my P-trap fixture about an inch and a half too close to the wall to line up with the pipe it's supposed to screw into.
    For whatever reason, the picture got rotated when i posted it here. Tilt your head to the left and you'll be in business.
    I'd need a J-bend that's a real real tight U shape to make this work. Does that exist and/or is it even up to code to do that? I'm 100% new to this and thought some basic handyman skills would allow me to swap out a simple basin and cupboard, but I guess not! All suggestions are welcome!
    Thanks
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Perhaps the simplest option would be to move the sink a few inches to one side or the other so that the trap will line up when turned. Alternatively, the existing trap adapter could be cut off and a new one installed closer to the wall. Use care to make the cut in the right place or you will need to open up the wall to replace the sanitary tee.
  4. notbillcosby
    Sep 28, 2013
    Iowa
    Dang. I take it there isn't just a tight U-pipe that'd work? Moving the sink wouldn't be the biggest deal in the world, but it'll require moving the medicine cabinet mounted above it to keep things centered and that opens up a bunch more things I didn't want to work on. Modifying the pipes coming out of the wall sounds like it's maybe a little out of my league.
  5. ShockHazard
    ShockHazard New Member
    Nov 1, 2012
    Independent Contractor
    North East Pennsylvania
    Can you pan out more?
    I don't understand why the pipe coming off the drain is so close to the wall.
    The drain is at least a foot from the wall to begin with, right?
  6. notbillcosby
    Sep 28, 2013
    Iowa
    Here's more pictures. And no, the drain from the sink is about 7 or 8 inches from the wall. :-|
    Sorry again for the rotating. Can't really figure out why it's doing that.
  7. hj
    IF the sink is "directly" in front of the wall opening, you can use a "bottle trap" which does not have ANY bend in it. The trap function is internal to its housing, but for that reason it cannot be "rotated".
  8. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Search for "offset tailpiece" , and see if any of the results inspire you.
  9. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    You could 45 to the right where the drain comes out of the wall. Come out far enough so the trap will line up
  10. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    A 22 would work much better.
    John
  11. Reach4
    Sep 25, 2013
    Is that thread already coming out of the wall a common thread?
  12. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    +1
    hj has the right idea.
  13. WorthFlorida
    WorthFlorida USCG escorting cruise ship leaving Port Everglades
    Oct 28, 2009
    Retired
    Orlando, Florida
    Hello Not,
    It looks like the fittings at the wall are already glued and that makes it harder to try another way. From the wall use a 45 degree fitting and you can meet the p trap connection somewhere at the corner of the triangle. What? Take a look at the pictures. I had something similiar but for a kitchen sink but the drain was much further from the wall as you seem to have.
  14. Terry
    Aug 17, 2004
    Like John, I would have glued either a street 22 or a street 45 with a new trap adapter.
    There is plenty of room there to cut off the existing and for a new fitting there.
Similar Threads: Stupid newbie
Plumbing Forum, Professional & DIY Advice Stupid Newbie Question - Leaks in new faucet connection Aug 10, 2010
Plumbing Forum, Professional & DIY Advice Stupid shower rough in question, Body spray May 20, 2016
Plumbing Forum, Professional & DIY Advice question to recitfy a stupid mistake! Dec 4, 2011
Plumbing Forum, Professional & DIY Advice Stupid Firemen.... Aug 5, 2009
Plumbing Forum, Professional & DIY Advice !Stupid! pipe fitting question Apr 19, 2008
