Stuck tub drain fitting!!
Discussion in 'Shower & Bathtub Forum & Blog' started by Murphy625, Aug 1, 2013.
  1. Murphy625
    Murphy625 Member
    Jul 7, 2013
    Michigan
    My rental has a tub and shower that is leaking at the tub drain. It seems that somehow the brass elbow drain fitting has a crack in it or something.
    Anyhow, I took the pipe off but I can't get the piece that screws in through the top of the tub into the elbow below out. Its like the brass threads have been fused or something.
    In more proper terms (had to look this one up), the tub basket will not unscrew from the tub shoe..
    I was just going to return with the cordless sawzall and cut it off but thought I should ask her first.
    Any suggestions?
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  4. Murphy625
    Murphy625 Member
    Jul 7, 2013
    Michigan
  5. hj
    If the tube has come loose from the shoe, or is brittle so it WILL snap loose, NOTHING will unscrew it. You have to cut it out with a hacksaw blade and small chisel or screwdriver.
  6. Murphy625
    Murphy625 Member
    Jul 7, 2013
    Michigan
    That's what I did... Dewalt battery powered angle grinder with a cut-off wheel to the rescue! Took all of 60 seconds.. What sucks is the 35 minute drive to the rental unit...
Similar Threads: Stuck drain
Shower & Bathtub Forum & Blog Tub drain trip lever stuck in pipe Dec 6, 2016
Shower & Bathtub Forum & Blog Help adjust brass tub drain... I'm stuck Jun 30, 2015
Shower & Bathtub Forum & Blog Removing Stuck Shower Arm and Drain Dec 18, 2013
Shower & Bathtub Forum & Blog Stuck Tub Spout & Drain Flange Oct 20, 2011
Shower & Bathtub Forum & Blog bit stuck! don't know where to connect my bathtub drain... Jan 10, 2008
