Stuck Snake
Discussion in 'Drain Cleaning' started by Jimbob, Jan 17, 2009.
  1. Jimbob
    Jimbob New Member
    Jan 18, 2005
    The 2nd floor bathroom sink would not drain. Blockage is beyond the trap. Used a manual plumber snake and fed it down approx 8 feet. Couldn't go any further but when I tried to remove it, it wouldn't come out. Have tried clockwise and counter clockwise and it still won't come out. Have gone in thru the cleanout plug hole.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Time to call a plumber, or cut that pipe where you think it is stuck.
    You're going to find out how disturbing this task really is.
    I hope you didn't use drain cleaning liquids.
  4. Jimbob
    Jimbob New Member
    Jan 18, 2005
    Initially I did. Why?
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Because many so-called drain cleaners are quite caustic and create a hazardous working condition for the plumber. Be sure you inform the plumber you call what you use, how much, and when.
  6. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Also the drain cleaner weakens the drain cleaning cable, which in a short time can make it super brittle so it will just break in pieces. I have removed many many stuck snakes in the lines.
    Most common is where the home owner rents a machine to rod their main sewer and snap the cable in the line. The best one was a guy rented a medium machine thats used to clear 1 1/2 to 4 inch drains up to 50 foot. He ran the rod through his water closet on the second floor and sent out all 50 foot, then could not pull it back for the life of him. When we got there my buddy Mike ran the rod while I pulled the cable out, 20 minutes later we got the rod removed from the water closet. Problem was I had to grab the cable with such force I wore holes into my gloves and the friction from the cable caused large blisters on my hands. When we handed the guy the bill for a half hour and a service call, the guy said in shock " THAT MUCH!!! Only for 10 minutes of work!!" I told him it was 20 minutes, and then I looked at him then my hands then back at him. He all of sudden said will cash be alright?
Similar Threads: Stuck Snake
Drain Cleaning Electric Snake stuck in pipe Aug 25, 2014
Drain Cleaning Stuck snake in Vent pipe May 17, 2009
Drain Cleaning Plumber's snake stuck in pipe Sep 30, 2006
Drain Cleaning Camera Found Bit of Stuck Cable in Drain Pipe Aug 16, 2012
Drain Cleaning Drain still clogged after being snaked. Oct 9, 2015
