Stuck snake in Vent pipe
Discussion in 'Drain Cleaning' started by Nurpo, May 17, 2009.
  1. Nurpo
    Nurpo New Member
    May 17, 2009
    Cabinet Installer
    Florida
    Here it goes.
    In my second bathroom. Sink and toilet are backing up into the tub. The water drains slowly. I used a 30' power auger, in the tubs vent and drain with no luck. All so ran the power auger threw the toilet, no luck with that either. So I decided to use a Tape snake on the Vent from the roof. <--- Big mistake :eek:.
    The Snake is 3/4" wide by an 1/8" thick and has a pointed head that rounds off towards its back. Made it past the first 90 and that was it. It stopped shortly after that. and now it wont come back. Tried pulling with all my might, it just wont budge. Any suggestions on how to unstick it with out having to open the pipe where its stuck at? I've read threw the forums I saw that on cable augers the answer was to winch it. Will this work on a tape?
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Some people with the hand snakes ram to hard trying to make the turns and blow the back of the turns off. With out being there I can not give you any good advice , but if you did leave the pipe. Its time to open up the floor and remove the hand rodder that way.
  4. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    You got one of these stuck¿
    [​IMG]
  5. Nurpo
    Nurpo New Member
    May 17, 2009
    Cabinet Installer
    Florida
    Yeah thats pretty much it. The head is slightly different though.
  6. Nurpo
    Nurpo New Member
    May 17, 2009
    Cabinet Installer
    Florida
    Opened the wall and removed the copper incoming drain line from the sink, thought I'd get lucky and it would be stuck at that place. It indeed goes down to the slab and stuck in a 90 below the concrete. As SewerRatz suggest is breaking the slab apart my next course of action or is there another alternative?
    Thanks Guys for your opinions.
    [​IMG]
  7. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    I would hire a professional plumber !
    That knows how to cut the tee and remove your snake and has the size and
    kind of snake to properly clear the drain blockage and put the pipes back
    the way they should be ! ! !
  8. hj
    drain
    mistake #1. The vent was not the reason the drain was not working.
    #2. Flat tapes have a specific use, and seldom work, but the way you used it was not one of them.
    #3. cutting the pipe apart without knowing if that would cure the problem.
    Probably a few others, but you may be making the job more serious at each step you take.
  9. kingsotall
    Aug 17, 2008
    They did open one of these, didn't they¿
    [​IMG]
  10. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    YOU NEED TO PULL HARDER with leverage...
    We have gotten snakes stuck before,
    you need to pull harder, and perhaps try to devise
    some sort of handle that you can grip with,
    perhaps some HEAVY DUTY vice grips FIRMLY attached to the tape right above the vent stack....
    then you need to figure our some way to get some good leverage
    against the vice grips with a pry bar....
    attempt to pry up from against the vent stack or the roof.....
    their is a very good chance that it might pop loose with the leverage.
    ....or the vice grips will slip....
    just dont fall backwards off the roof when it does finally break loose.....
    ( yes I have done this before)
  11. Cass
    Cass Plumber
    Nov 12, 2005
    have you been trying to spin the tape while trying to remove it...
    Maybe enough 1" PVC with a 45 glued to it and slide it over the tape and down the vent as far as it will go and see if that will help get the tip into a different position...
  12. hj
    tape
    You have obviously NEVER tried to rotate a 3/4" flat tape, unless it is a very long straight pipe.
  13. Master Plumber Mark
    Feb 6, 2005
    hey now......
    hey now, their is no reason to get criticle of Cass and his recommendation.... LOL...
  14. freeflow
    freeflow Semi retired master plumber
    Aug 4, 2009
    plumber drain cleaner
    alabama
    stuck
    Try pouring a qt of motor oil down stack and twist it around with the vice grips and JERK HARD
  15. edcrazy
    edcrazy New Member
    Aug 25, 2009
    Worked for me
    I tightened the set screw as tight as I could as near the clean out as I could and picked the whole machine up and used it like a slide hammer. 4 bangs and the snake was FREE!! I tried the come-a-long, that didn't work.
Similar Threads: Stuck snake
Drain Cleaning Electric Snake stuck in pipe Aug 25, 2014
Drain Cleaning Stuck Snake Jan 17, 2009
Drain Cleaning Plumber's snake stuck in pipe Sep 30, 2006
Drain Cleaning Camera Found Bit of Stuck Cable in Drain Pipe Aug 16, 2012
Drain Cleaning Drain still clogged after being snaked. Oct 9, 2015
