Stuck lav drain
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Mad Plumber, Sep 5, 2006.
  1. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    I am a single mom of 4 kids, and as you can imagine, money is tight... so if I can do this myself, I would be thrilled:
    On our bathroom sink, you pull up on the top of the faucet and this pull the drain closed. When you push it down, it is then supposed to open. It doesn't.
    I cannot get it to open.
    I can wedge my fingernails in the crack and manually lift it and hold it open to drain water... but I can't get it to stay open.
    Is there anything I can do?
    THANKS!
    Stacie
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Use a small flat screwdriver to lift that pop-up assembly. That pop-up is either resting on top of the rod or it is threaded through the pop-up rod. If it doesn't remove easily than most likely the rod is holding it in place. Adjustment of the linkage can sometimes correct the problems associated with pop-up drain assemblies.
    More than likely you will find nasty hair and gunk that has built up over time.
    What could be your situation is that the rod either rotted off that actuates the pop-up assembly or there is limited movement in the swivel of the pop-up rod.
    I would say just see if the plug will come out; inspect/clean and see what is actually wrong with the mechanism.
  4. jadnashua
    If you crawl under the sink, you'll see a rod coming out of the drain pipe. This usually has some sort of clip that attaches to the rod with a knob you use to open or close the stopper. If you can move that lever, see if the stopper moves. Take a look at the stopper once you get it out. That lever that screws into the drain pipe usually is set up so it sticks into the bottom hole of the stopper. There is a nut around that lever, that, if you unscrew it, the whole lever will come out. It is possible that the part of the lever that is inside of the drain is corroded or broken off.
    Let us know what you find.
Similar Threads: Stuck drain
Plumbing Forum, Professional & DIY Advice Flapper Getting Stuck in drain hole Aug 16, 2016
Plumbing Forum, Professional & DIY Advice Removing stuck tub drain bushing Jun 26, 2016
Plumbing Forum, Professional & DIY Advice Tub Drain plunger separated from linkage, stuck in drain pipe May 2, 2014
Plumbing Forum, Professional & DIY Advice Oatey drain plug stuck Mar 23, 2014
Plumbing Forum, Professional & DIY Advice Touch Down Drain Stuck Jan 29, 2014
