stuck foot valve
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by wildernessj, May 24, 2008.
  1. wildernessj
    wildernessj New Member
    May 24, 2008
    Hello, I have a 4 inch well with a 2 line system. I tryed to pull my lines up to replace or clean my foot valve and venturi but it will not come up with 2 guys pulling on it. I am afraid of breaking off the lines and not being able to get new lines down. Any suggestions?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If you could go down with some 1" Pipe to the Jet and bump it downwards, you might be able to free it up. It's probably glued to the Casing with Minerals. Once you get it to move, it should come out without too much problem. Then put a Submersible Pump back in. You'll be much happier.
    bob...
Similar Threads: stuck foot
Pumps and Tanks Well Forum & Blog. Water is life. Adding check valve for temp fix for stuck foot valve? Dec 19, 2013
Pumps and Tanks Well Forum & Blog. Water is life. several foot valves stuck in well casing! May 3, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Stuck open check valve in the well Dec 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Stuck pump trying to drop Jun 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well pump stuck 1" poly, not doing a thing, yet pump checks out okay?? Jun 19, 2014
