Stubborn kitchen sink venting problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Meta, Jun 30, 2013.
  1. Meta
    Meta New Member
    Jun 30, 2013
    CT
    I did a full house remodel a few years back, including all new plumbing. The new kitchen sink has been plagued by a very slow drain relating to what I think is a flaw in the way the air vent was installed. Both sinks routinely fill with water while washing dishes and drain at a snails pace. The flow can me marginally improved by turning on the garbage disposal that seems to inject air into the system and allow it to flow at a slightly faster snail's pace. Removing the air vent entirely allows the sink to clear and flow very rapidly. Bad air vent? Nope. My plumber replaced it after I asked him to fix the problem. He even we so far as to experiment by installing two vents, thinking one was not providing enough air. My thinking is that we have a design problem with the system that's causing the vent to lock up with water before it's able to allow air into the system. I've attached some pics for the gurus here to have a look at at. My plumber is suggesting drilling through the wall to the outside to utilize a traditional open air vent. If rather not have an ugly pipe outside my house in a conspicuous location and would prefer to solve this more intelligently. Any thoughts here? Much appreciated!
    [​IMG]
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    I have disassembled several types of AAV’s and some have very small openings. Some are very simple and the price is low but may not allow enough air into the pipe. Some that cost a little more have better designs and allow more air in when needed.
  4. Meta
    Meta New Member
    Jun 30, 2013
    CT
    That's what my plumber thought, that it was not getting enough air. So he temporarily installed two vents where now you see only one. Two vents made no difference at all and the sinks continued to be extremely slow so he went back to a single vent. I suspect the vent is locking up with water immediately and then the system "breathes" through the sink drains. The drains gurgle with air constantly as it very slowly drains.
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    You have a sag somewhere in the drain line
  6. Meta
    Meta New Member
    Jun 30, 2013
    CT
    Do you mean a sag between one or both of the traps and where it goes into the back of the cabinet and then down the waste pipe in the wall? I didn't look at the pitch carefully, but could a small negative pitch towards the trap over such a small section cause the problem? What explains the good flow without the air vent? I'm still struggling to conceptualize this problem.
  7. jadnashua
    The vent prevents the traps from siphoning, not generally a factor in whether the pipes drain or not. An unvented S-trap drains too well, siphoning itself, which is why they are illegal. A garbage disposal can put a lot of crud into the line - it's likely, as Tom said, there's an issue, most likely with the slope or linearity of the drain line and there may be a partial clog.
  8. hj
    Your drain line is partially plugged. When the sink tries to drain it has to push the air out of the drain line. The obstruction prevents it from moving down the pipe, and the air vent WILL NOT let it vent under the sink. IF you had a conventional vent, the line would still be restricted, but the air would be released up the vent pipe. The disposer, (NOT a "Disposal"), is a pump that forces the air down the pipe. It is not "letting air into the pipe".
  9. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    As Jim said, the purpose of the vent is to allow air in, to break the siphoning. If air needs to be let out of your drain to get it to work, it suggests that there is a problem with your drain lines somewhere after it disappears into the wall.
    The best analogy I can think of is trying to fill a pop bottle. As you try to pour water in, the air needs to come out the same opening.
Similar Threads: Stubborn kitchen
Plumbing Forum, Professional & DIY Advice Stubborn kitchen pipe Dec 22, 2011
Plumbing Forum, Professional & DIY Advice How to remove stubborn tank bolt? Nov 26, 2016
Plumbing Forum, Professional & DIY Advice Stubborn tub spout.. help! Nov 14, 2016
Plumbing Forum, Professional & DIY Advice Stubborn Hose Bib May 7, 2014
Plumbing Forum, Professional & DIY Advice Stubbornly clogged drain Mar 10, 2013
