Stripes over leach field
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by littlebrook, Aug 15, 2008.
  1. littlebrook
    littlebrook New Member
    Aug 14, 2008
    Not a plumber
    Rochester, NY
    Hi,
    We had our leach field replaced about 3 months ago with new infiltrator chambers after our 43 yr old pipe and gravel system collapsed. I've since re-planted grass seed over the leach field but now I've noticed that I have yellowish-green stripes interspersed with normal green grass over the leach field, corresponding with where I think the lines are located. Is this normal? We have had lots of 80+ F days this summer along with (almost daily) heavy thunderstorms so the lawn has been getting a good amount of water I think. I know that lush bright green grass can be a bad sign but there is no surface effluent and the ground is hard, not mushy.
    Thanks
  2. Master Plumber 101
    Master Plumber 101 In the Trades
    Aug 11, 2008
    Wisconsin
    I live in a populated area in Wi where Powts is rarely installed if at all. Leech beds are not legal in Wi.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Hard ground is a good sign. Mushy would be bad.
    The difference in color is quite common.
  5. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Didn't someone write a book titled the grass grows greener over the septic tank?
  6. littlebrook
    Aug 14, 2008
    Not a plumber
    Rochester, NY
    Hi,
    Yes, I tried to google an answer and all I got was the grass is always greener over the septic. Also most answers I got were to do with lush bright green grass and mushy ground over a failing leach field and nothing about yellow or brown stripes.
    Thanks for the replies
  7. Redwood
    Dec 15, 2007
    Service Plumber
    Erma Bombeck wrote the book.
  8. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    that's It !
  9. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    What???!!!!!
    If you're a master plumber, and you don't know about private sewage systems,
    What state do you reside in that has a city sewer only systems?
    I know the answer already, it doesn't exist.
    BTW, I follow NPC in KY and we had to know the basic components of how that system worked since the building sewer always connected to such systems where public sewers were not offered.
  10. Dunbar Plumbing
    Apr 18, 2005
    When the contractor came in, did he do a perc test to determine the amount of minutes it takes for the soil to absorb water?
    Did he scrape an area to put topsoil back in where the leach fields are?
    No topsoil or minimal topsoil cover will cause a great deal of problems. If the ground is turning brown over the chambers.......means for one that the dirt lacks nutrients to keep growth going. Rainfall isn't helping this matter as well.
    Topsoil is key crucial to absorption process in those systems.
  11. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Yes, it sounds like the area was not properly re-covered with topsoil capable of producing grass. The leach chambers should be providing plenty of water for the grass by way of evaporation, but now you might need to add a little mulch or some nutrients to get grass or whatever thriving again.
    "Many are called, but few get up!" (Erma Bombeck)
  12. littlebrook
    Aug 14, 2008
    Not a plumber
    Rochester, NY
    Hi,
    The contractor who installed the system did a perc test that showed with have very fast absorption rates because we have sandy soil. The perc test was done at a depth of about 12-18 inches I think. However, he ended up installing the infiltrators at a depth of 2 feet due to the need to create proper slopes from the tanks to the D-box and the lines. So the lines should be covered with plenty of topsoil (almost 2 feet).
    Right now, all seems to be working fine and as I mentioned no mushy areas but I was just curious why I would see stripes and if this was a bad sign.
    Thanks for the advice.
  13. leejosepho
    Nov 23, 2006
    Our ground here is also sandy, and part of our yard actually has a nutrient-rich topsoil on top of our sandy soil that does not support grass very well. So, maybe you now need a little "black dirt" where your actual topsoil and sandy ground got all mixed together during excavation if the actual topsoil was not specifically set aside for re-application after the sandy-soil backfilling (covering your chambers) had been completed. Other than that, I do not know of any reason your new leach field would inhibit good grass growth.
  14. littlebrook
    Aug 14, 2008
    Not a plumber
    Rochester, NY
    I think you're probably right. When they installed the new lines, they dug deep trenches so the topsoil was only really disturbed in those areas which may explain the stripes. Will probably need to invest in a big delivery of new topsoil to help the grass grow better.
    Thanks for all the advice.
  15. Redwood
    Dec 15, 2007
    Service Plumber
    Apparently the plumbers union in Wisconsin doesn't deem this to be a significant part of what a master plumber should know... Amazing!
    Absolutely Amazing!
    Google This!
Similar Threads: Stripes leach
Plumbing Forum, Professional & DIY Advice Weird leach line assembly. Today at 10:57 AM
Plumbing Forum, Professional & DIY Advice New Leach Field (1 week old) water above ground. Jun 14, 2015
Plumbing Forum, Professional & DIY Advice Is It OK (For My Pipes In The Crawl Space) If I Disinfect The Crawl Space With Bleach Aug 12, 2012
Plumbing Forum, Professional & DIY Advice Copper leach ? Feb 8, 2012
Plumbing Forum, Professional & DIY Advice leach bed Jun 29, 2010
