Straps for PVC DWV
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by r_ventura_23, Jun 5, 2014.
  1. r_ventura_23
    r_ventura_23 Member
    Apr 24, 2014
    NJ
    What is the best way to strap pvc vents in an attic that are running horizontally(with a slight pitch)? They only run a few inches above the floor, and the ceiling is anywhere from 4 to 6 feet higher then the vent pipes. Should I attached the straps all the way to the roof rafters or is there another way to support these pipes?
  2. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    Cut blocks of the right heights from 2X4's or 2X6's and toenail them to the floor with nails or screws. Then strap the pipe to those.
  4. r_ventura_23
    r_ventura_23 Member
    Apr 24, 2014
    NJ
    Thanks. That sounds easy enough!
  5. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    You're welcome. Two other tips:
    1) Pre-drill the holes in the blocks whether you use nails or screws: it will prevent splitting and make installation easier.
    2) Put some construction adhesive on the underside of the blocks to increase stability.
  6. r_ventura_23
    r_ventura_23 Member
    Apr 24, 2014
    NJ
    One more question. Should I wrap the strap completely around the pipe or just enough to tie into the 2x4 over the pipe and back into the 2x4. Also, what kind of straps do most people use?
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Just curious, but what is PVC pipe doing in your attic? PVC can only be used for drain lines inside a house. Perhaps you mean CPVC?
  8. DaveHo
    DaveHo Member
    Mar 12, 2010
    SE PA
    OP described these pipes as vents. If they are plumbing vents, I don't believe you are permitted to run them horizontal in the first place.
  9. Sluggo
    Sluggo Member
    Mar 28, 2014
    Washington
    OP-
    If you make the blocks not much wider than the pipe diameter, or you have the blocks under and parallel to the pipe, you can simply put a strap over the top and screw it down on both sides. I see no value in wrapping the strap completely around.
    DaveHo-
    You can run a vent horizontal as long as that section is at least 6" above flood level of any fixture it serves.
  10. Terry
    Aug 17, 2004
    You can use PVC for waste and vents most places, and ABS fewer places.
    If a vent's horizontal is more than a 1/3 of the total vertical, it needs to be upsized one dimension. Most of the time it's not an issue.
Similar Threads: Straps
Plumbing Forum, Professional & DIY Advice Support Straps Apr 12, 2009
Plumbing Forum, Professional & DIY Advice Support straps on Vents and Drains Apr 30, 2008
Plumbing Forum, Professional & DIY Advice water heater code (straps exspansion tank) Dec 17, 2007
Plumbing Forum, Professional & DIY Advice copper pipe straps, solder? Aug 13, 2007
Plumbing Forum, Professional & DIY Advice copper pipe straps Feb 17, 2007
