Strange problem with Glacier Bay Kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by juriggs, Apr 3, 2013.
  1. juriggs
    juriggs New Member
    Apr 3, 2013
    Littleton, CO
    Whenever I turn on my shower, my kitchen faucet begins leaking. It's not just a drip... it's a stream of water. This is just the hot water... if I turn on the cold water, nothing happens. Also, it doesn't happen in reverse... if I turn on the kitchen faucet, no leaking from the shower head.
    Any help would be appreciated. I'm selling this house, and want to resolve this before closing.
    Thanks,
    Justin
  2. hj
    WE would have to know the make and model of the sink faucet, so we could decide IF a drop in pressure could activate it. Does the "flow" stop when you turn off the shower, or do you have to do it yourself? Is the faucet mounted to the wall or on the sink?
  4. juriggs
    juriggs New Member
    Apr 3, 2013
    Littleton, CO
    The sink is a Glacier Bay model number F8FA0000BNV. The leaking stop when we turn off the shower, But I should've mentioned that it starts when we have the washing machine on as well. The faucet is part of the sink not mounted to the wall.
    Thanks for the help!
  5. Seattle2k
    Seattle2k New Member
    Nov 14, 2012
    Seattle
    Glacier Bay....check the cartridge and seals. I'm guessing a low-flow showerhead is causing the shower's hot water to feed over to the cold line, of vise versa, and the increased pressure in that line is backing up to the point of least resistance, being the crappy Glacier Bay faucet.
  6. hj
    IT has a ceramic disc seal so it should NOT "separate" when the pressure changes. Since it does, you need a new valve insert.
  7. juriggs
    juriggs New Member
    Apr 3, 2013
    Littleton, CO
    Thanks, I'll try that and report back
Similar Threads: Strange problem
Plumbing Forum, Professional & DIY Advice Strange problem with baseboard behind toilet Aug 20, 2015
Plumbing Forum, Professional & DIY Advice Strange kitchen sink drain problem Sep 1, 2014
Plumbing Forum, Professional & DIY Advice Strange Drain Pipe Problem Apr 7, 2014
Plumbing Forum, Professional & DIY Advice Gravity recirc loop strange problem Oct 29, 2010
Plumbing Forum, Professional & DIY Advice strange kugler faucet problem May 25, 2010
