Strange Behavior for a Toto
Discussion in 'Toilet Forum discussions' started by matt0664, Jan 14, 2006.
  1. matt0664
    matt0664 New Member
    Jan 14, 2006
    Alright, I just remodeled my bathroom. Apart from adding a 3" drain for my shower, and a new 2" vent I did nothing else with the pipes. I put in a new Toto two piece pacifica. I love the toilet. It was working well, for about a week until it woke me at 4am this morning with a strange gurgling sound. I flipped the lid to see large air bubbles coming up into the bowl
    I tried flushing the toilet but it only filled with water
    slowly, the water subsided
    I plunged it- gasp! but the only change was that it drained a little faster
    Gone is the mighty flush
    What happened?
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Sounds like your sewer line is backing up. Toilets do not make air bubbles, like your describing, on their own.
  4. matt0664
    matt0664 New Member
    Jan 14, 2006
    toto
    The toilet is in the basement. However, there is a check valve installed -about 30 feet away- in the waste line.
    An additional note: The toilet went back into normal mode later on in the morning, but I'm still hearing intermittent gurgling noises and seeing air bubbles.
    PS> the check valve was installed years ago for the very reason you mentioned- our street seems to have a problem with the main line which caused the prior owner's rec area to fill with...you can guess what.
  5. jadnashua
    Check valves often don't seal completely, especially after they get older and things get trappped in their sealing area. Yours could be leaking a little. Nothing to do with your toilet.
Similar Threads: Strange Behavior
Toilet Forum discussions Toto Drake fill valve makes strange noises Jul 24, 2014
Toilet Forum discussions Toto UltraMax II Sounds Like It's Leaking Then Makes Strange Noise May 6, 2013
Toilet Forum discussions Strange find Jan 1, 2013
Toilet Forum discussions Another leaking toilet, but strange Jan 7, 2009
Toilet Forum discussions Very Strange condensation on side of toilet Mar 10, 2008
