Strange architectural lighting wiring
Discussion in 'Electrical Forum discussion & Blog' started by Backglass, Jan 14, 2008.
  1. Backglass
    Backglass New Member
    Jun 6, 2007
    New York
    Hey all,
    We moved into our current money pit about eight months ago. It was a foreclosure/eviction so many things were non-working including numerous 120v architectural lights in the front yard/drive area.
    Saturday we had nice weather and I got a wild hair to try and trace out what was wrong and after pulling the first light was surprised to see SIX wires and a rainbow of colors below. I got out my Fluke and figured out I had at least two circuits. This is what I found:
    Blue - Hot #1
    Green - Ground
    White - Common
    Brown/Yellow - Hot #2
    Red/Orange - ?
    White w/orange tape - ?
    Now I found a loose wire from the lights and got them working but my questions is: Is this kind of multi-color wiring normal?! When I first saw the colors my first thought was that they were running the well wiring through this post! (it's in the vicinity)
    Also there is a GFCI outlet in the area (showing a "brownout"...about 60 volts) so could all these wires be for that? Do you normally wire 120v architectural lights up to a GFCI?
  2. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    There could be multiple hot wires and a common nuetral (should be larger), especially if they're individually switched. Can you follow the conduits and open up a few more of the lights or junction boxes and trace it out?
  4. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Your guessing, you need to open everything up and make a map of what is doing what, check inside your house to see if they are switched or hot, the hot ones could possible be for receptacles... but your the one that has to do the homework...
  5. Backglass
    Jun 6, 2007
    New York
    No, I'm asking. ;) Is this kind of multi-color wiring normal for the electrical professional?
    Thanks all.
  6. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Sure, for ungrounded conductors any color will work except green which is only for grounding conductors, and you have gray and white for grounded conductors...
    You should feel lucky to have so many colors, makes the job easier figuring out what does what...
  7. Backglass
    Jun 6, 2007
    New York
    Makes sense to me. Thanks!
  8. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Hope you can figure it out... it really should not be too bad...
Similar Threads: Strange architectural
Electrical Forum discussion & Blog Strange Dimmer Switch Wiring Jan 6, 2017
Electrical Forum discussion & Blog Strange electrical experiences Apr 1, 2016
Electrical Forum discussion & Blog Strange Voltage Drop When Light Bulb is Installed Aug 8, 2015
Electrical Forum discussion & Blog Strange Ant Problem - FYI May 22, 2015
Electrical Forum discussion & Blog Help with strange light fixture wiring Apr 15, 2013
