Strang leak from washing machine
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seemomgo, Feb 17, 2005.
  1. seemomgo
    seemomgo New Member
    Oct 8, 2004
    My whirlpool washer is 9 years old. It washes fine, but a few hours AFTER washing, there is a puddle of water on the floor under the washer - mostly toward the front end.
    The hoses and connections are fine...why would a leak show up so long after washing, and how do I repair it? I'd appreciate any replies as the Whirlpool customer service was of no help at all.
  2. jasonmcl
    jasonmcl New Member
    Feb 7, 2005
    Sounds like the pump
    I had the same problem and it ended up being the pump. I replaced it myself for $40. Look for corrosion on the motor shaft connected to the pump to be sure.
  4. keithdeanne
    keithdeanne New Member
    Feb 13, 2005
    Pennsylvania
    could also be the mixing valve located on the top of the washing maching tub.
    It's a tiny plastic peice that looks like an cone and surrounded by a rubber sheath. the sheath could be your problem. after time it drys out and cracks and then leaks causing the puddle you are noticing.
  5. hj
    leak
    In some cases it can be the drain pipe overflowing and filling the wall, but then it takes a while before it can leak out.
  6. seemomgo
    seemomgo New Member
    Oct 8, 2004
    removed pump...
    I've gotten as far as opening up the washing machine...I removed the pump and water came flowing out when I disconnected the bottom hose (which connects to the drainage hose and out to the wall...sorry I don't know the technical terms for everything.) There was also a little bit of water in the pump as well.
    Does that sound like a pump problem or something else?
    Thanks!!!
  7. Bob's HandyGuy
    Bob's HandyGuy Senior Member
    Sep 10, 2004
    You should have left all the parts intact and removed the cabinet. First, unplug the machine! Cabinet comes off easily by unsnapping the plastic covers each side of the console, screws at each side and bottom of the console, then prying off the the two retaining clips. Unplug the wires. Swivel the console back on it's hinges, tilt the cabinet forward and lift it off the pegs on the base. You can then observe where the leak is coming from. Front of the machine leak suggests the hose connections to the pump, or the pump itself is not sealed properly. I suggest you purchase a repair manual. This is a good site for washer repairs. http://www.bobvila.com/BBS/Appliances/flat-page1.html
  8. Bob's HandyGuy
    Sep 10, 2004
    Sorry, I didn't really answer your original questions. Water leaks after the machine is off because there is always some residual water left. That's why it must be winterized with RV anti-freeze if left in an unheated area.
Similar Threads: Strang leak
Plumbing Forum, Professional & DIY Advice strange leak Feb 7, 2009
Plumbing Forum, Professional & DIY Advice Very Strange Plumbing Issue Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Strange problem with baseboard behind toilet Aug 20, 2015
Plumbing Forum, Professional & DIY Advice Strange water pressure issues. Nov 7, 2014
Plumbing Forum, Professional & DIY Advice Can't remove strange closet flange anchoring screws, help! Oct 14, 2014
