Stove Wire Repair
Discussion in 'Electrical Forum discussion & Blog' started by Kiko, Mar 6, 2011.
  1. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    One of the wires to a stove burner shorted out (I think the cleaning lady had pulled on it ). Now, I need to cut off several inches of burned out wire and add a few inches of new wire so it will be long enough to reach the ceramic connector at the burner.
    The wire says 150 C, but I can't make out the AWG. Does anyone know the correct replacement wire for this, and if I can just use a high temp wire nut to complete the repair?
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Instead of repairing the conductor why not replace the entire length using a Type Z or TFE conductor?
  4. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    My other option is to replace the entire wire harness, which I would prefer to avoid, since I only need about 4" of wire replaced.
    My main concern is finding the correct gauge wire. I called two place that sell high temp conductors by the foot, but they are both 14 gauge. That just doesn't seem right for a stove burner??
  5. jimbo
    jimbo Plumber
    14 ga. wire will handle 15 amps. That is 3600 watts, 240, and the burners are not that big.
  6. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    If you insist on patching the wire please use a ceramic wire nut
  7. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I've already bought the ceramic wire nut. :)
    Second question: is there a place on my Croc's wire stripper to crimp on a high temp crimp terminal? Can a pliers work? Or do I need to buy a special crimper?
    [​IMG]
    [​IMG]
  8. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    why not just buy a ceramic twist on wire nut?
    The use of a pressure connector you take a chance of damaging the insulation and you will be right back to where you are now
  9. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    The ceramic wire nut is to connect one end to the existing conductor. The crimp-on terminal is what is needed to connect the other end to the burner. A screw passes through the eye of the terminal, and holds it in place. So, will I need a special crimping tool, or will my Croc's work for this?
    [​IMG]
  10. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Yes I am stupid and this proves it.
    Squeeze her down
  11. jadnashua
    Because of the heat, there is more expansion/contraction of the connectors and it becomes somewhat critical to ensure you get a good crimp. If it isn't tight enough or properly indented, it can loosen, change the resistance, and fail again. There are calibrated crimping tools that won't release until you've completed the proper compression. They have fingers or shaping dies designed for the specific connector, wire size, and application. You may not have trouble, but it is a potential weak point if it is not done well.
  12. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    Turned out, I didn't need to splice in any new wire. I just crimped on new terminals (I ended up replacing four terminals) using a vice grips and got a nice crimp.
    Thanks to all who responded. :)
  13. hj
    If you did NOT get a good crimp, you will eventually know about it when the added restistance causes the connection to burn out again.
  14. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    message deleted, I told you this type of post would not be allowed
    See the highlighted part in the quote above
  15. ballvalve
    Dec 28, 2009
    northfork, california
    How do you crimp anything with vice grips? May as well use a hammer.
  16. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    I thought it was strange too, but the owner of the hardware store where I bought the terminals suggested it, and the connections seemed very good.
  17. Kiko
    Kiko Member
    Jul 20, 2009
    Royal Oak, Michigan
    The connections only shorted out after the house cleaner pulled on the wires when cleaning the stove. I pulled hard on these crimps, and they seemed very solid. I'm not sure what you mean by "added resistance" ???
  18. jadnashua
    If the connection gets loose, it will act like a resistor, heat up like the heating element. The connector metal has some spring to it. Once heated and cooled depending on how good the connection is, it can lose its temper or springiness, and when it expands, not contract again so it no longer makes a good connection. That's why the crimper tool is more science than art...hard to determine if you got a proper crimp. Often, it really doesn't matter much. But, on high current and things like heating elements when exposed to extremes in temp, it can make a big difference. Time will tell. The proper crimping tool takes this all into account, and uses the best shape and compression to form a reliable, long-lasting, low resistance connection. SOmetimes, this is overkill; sometimes, it is essential.
  19. ballvalve
    Dec 28, 2009
    Which is why its a very good practice to re-torque large breakers with aluminum cables in them sometime after installation.
Similar Threads: Stove Wire
Electrical Forum discussion & Blog Adding Ground Wire to Kitchen Stove Jan 19, 2015
Electrical Forum discussion & Blog New 220 4 wire stove and old 220 three wire plug Mar 17, 2008
Electrical Forum discussion & Blog 50 amp stove line question Sep 9, 2013
Electrical Forum discussion & Blog KitchenAid gas stove model#KGRS807SSS Aug 31, 2012
Electrical Forum discussion & Blog Stove/Range circuit Aug 5, 2010
