Stopper won't hold water in new bath sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by polock, Oct 17, 2011.
  1. polock
    polock New Member
    Oct 17, 2011
    Virginia
    A plumber installed a new 19" round bathroom sink in the vanity. Same size as the old sink. We kept the same faucet and drain. The stopper is the lift rod to close drain, push rod down to open drain. The plunger won't hold the water in the basin. Called Moen, they sent a new plunger, and it won't hold the water either. The plumber doesn't know why. Has anyone got a remedy for this, a new sink that won't hold water is useless. Do they still make those old push in rubber stoppers?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    My guess is that it's leaking between the drain and the porcelain into the overflow cavity.
  4. polock
    polock New Member
    Oct 17, 2011
    Virginia
    do you mean the water's going out from under the metal drain collar?
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Yes. My guess is the plumber didn't seal it well enough. Easy enough to test with a $1 rubber stopper.
  6. polock
    polock New Member
    Oct 17, 2011
    Virginia
    Do you know how I can fix it? I'm a 66 yo female non-plumber.
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Assuming the stopper and the rod has been removed, do as follows:
    Loosen the jam nut under the sink so that the trim can be unscrewed from above. Roll some Plumber's Putty in your hands to warm and soften a finger sized length and form it into a donut under the trim. Screw the trim back into the drain. Tighten the jam nut underneath. Clean up the excess putty that will mush out from under the trim.
  8. polock
    polock New Member
    Oct 17, 2011
    Virginia
    You're right, I bought the plug and the water still seeps outs. I'm going to call the plumber to come back, he should have known that, he's been doing this for many years. My thanks to you for helping.
Similar Threads: Stopper won't
Plumbing Forum, Professional & DIY Advice Identify Sink Stopper Jun 20, 2016
Plumbing Forum, Professional & DIY Advice Toilet Under the Rim needs a good clean and I need a good stopper Oct 3, 2015
Plumbing Forum, Professional & DIY Advice Sink Stopper Caused Leak Below Sink (see video) - Pushed Down Stopper - Heard Pop Jun 5, 2015
Plumbing Forum, Professional & DIY Advice Bathtub drain stopper for 1959 tub Jan 31, 2015
Plumbing Forum, Professional & DIY Advice drain stopper rod clip May 2, 2014
