Stop the water!!
Discussion in 'Shower & Bathtub Forum & Blog' started by Tia83062@yahoo.com, Aug 24, 2007.
  1. Tia83062@yahoo.com
    Tia83062@yahoo.com New Member
    Aug 24, 2007
    Hi,
    We just installed a whirlpool bathtub. All fine and dandy. We also still wanted a shower. Thats good too except that the water runs off the back of the tub onto the floor. The back of the tub has a lip and it keeps the water from going back into the tub. Also the front of the tub pours onto the floor too. There isnt a lip. We need to put some kind of barrier on the side of the back part of the tub so the water runs back in. Also the front needs something to stop it from going on the floor!! HELP ME!!!!!:eek:
  2. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Hard to picture your setup with so few details.
    Photographs would help...
  4. jadnashua
    It sounds like you have a drop-in tub that you want to become a tiled shower as well. A tub designed for use as a shower would have a flange on three sides. Manufacturers also often make an add-on flange. This get glued on, then the walls get built so they come down over the flange with a vapor barrier behind it, then cement board (cbu) on the walls at least up to the height of the showerhead. Then some tile on top of that. More details are available over at www.johnbridge.com.
    If your finished walls are already up, buy a ceiling mounted shower curtain.
Similar Threads: Stop water
Shower & Bathtub Forum & Blog how to stop water from coming out facet instead of shower head Sep 25, 2013
Shower & Bathtub Forum & Blog tub drain linkage assembly not stopping water Apr 25, 2011
Shower & Bathtub Forum & Blog Shower stops working after water heater replacement Jul 6, 2009
Shower & Bathtub Forum & Blog Cannot remove lift and turn stopper Apr 14, 2017
Shower & Bathtub Forum & Blog Moen single handle shower is slow to fully start and slow to stop Dec 28, 2015
