stinky hot water
Discussion in 'Water Heater Forum, Tanks' started by ac44, May 4, 2009.
  1. ac44
    ac44 New Member
    May 4, 2009
    i moved into my home a year ago (after the home sat on the market for 1-2 years). I quickly found that the hot water smelled like rotten eggs, so i did some research online and figured it was from the hot water sitting in the tank for too long. i drained the tank, which only worked for a few days. i did more research, tried bleaching and draining the hot water heater and my pipes. once again, it only worked for a few days. finally, i had the anode replaced. this also worked for a short time,but the next time i went away for a weekend, the smell came back. i decided to buy a new hot water heater, because the smell is only coming from the hot water so i know the problem is in the tank. But the smell is back! I called the hot water heater manufacturer who reports it must be the anode and that it is the only part of the water heater that is not covered under warranty. I don't know what else to do. This is getting expensive and time consuming, and I am wondering if I will ever have normal hot water. Can anyone help?
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Did you just change the anode to another magnesium anode or, did you switch it to an aluminum anode?
  4. ac44
    ac44 New Member
    May 4, 2009
    not really sure, a plumber did it. what do you recommend? is there a solution that will work long-term?
  5. Redwood
    Dec 15, 2007
    Service Plumber
  6. rcatty
    rcatty New Member
    Jan 6, 2008
    Illinois
    change rod
    I just installed two new hot water tanks. I am on a well, and was told by a plumber that the wrong anode rod would cause me "odor" problems. I researched the issue and learned that you need an aluminum rod, not magnesium. Also, my AO Smith manual indicates the same thing. Finally, my water softener guy used to run bleach through my system to remove a rotten egg smell in my water.
Similar Threads: stinky water
Water Heater Forum, Tanks stinky water despite electrical anode Feb 24, 2013
Water Heater Forum, Tanks Electric Hot Water Tank Suddenly Stinky Nov 17, 2009
Water Heater Forum, Tanks Water Heater TP Valve Discharge Location - basement w/ no drain Tuesday at 3:50 PM
Water Heater Forum, Tanks Water heating Monday at 7:57 PM
Water Heater Forum, Tanks My T&P valve is expelling 1 cup of water per day Monday at 11:17 AM
